Battery level is fluctuated when turning on auto start stop
Old Oct 19, 2024 | 07:23 AM
Tv1982's Avatar
Gle 400d v167 2019
In the MBUX screen under Info > Engine, you can monitor the battery voltage. While the car is running with auto start-stop enabled, I observe the voltage fluctuating between 12.5V and 14.8V. However, when I disable the start-stop feature, the voltage remains stable at 14.7V.
I'm curious about why this happens. I think that when the car is running, the alternator is functioning as well. It seems the auto start-stop system may disconnect the alternator or halt battery charging to assess the battery voltage for stopping the engine. During this time, the voltage fluctuates between the battery's voltage and the alternator's output. This could mean that the start-stop function results in less efficient battery charging and may negatively impact the battery due to frequent short charges. I do not know if AGM battery like short charge or not.
Please correct me if I am wrong.
Old Oct 19, 2024 | 09:29 AM
streborx's Avatar
Top Answer: 1
G550
When the battery is being charged by the alternator, ~14.5 volts is normal. When start/stop is being used, the alternator isn't operating in the stop mode, and normal battery voltage ~12.5 volts is present.
The topic is controversial, but IMO start/stop accelerates the wear on the battery and starter. Mostly, I just find the feature annoying and of no fuel efficiency benefit to me, so I've permanently disabled it.
Old Oct 19, 2024 | 09:48 AM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
12.4v is considered fully charged for a resting 12v battery. When running the alternator provides ~14.4 - 14.8v to charge. That's perfectly normal and expected.
Old Oct 19, 2024 | 09:58 AM
JettaRed's Avatar
Veteran: Army
I have disabled the Start/Stop feature permanently. If you search, you will find that Start/Stop is not beneficial to the engine or transmission, but only provided by the manufacturer to help meet fleet mileage mandates. Since virtually all new cars have it, it is more of a novelty for the uninformed. Do your engine and transmission a favor and disable it. The fuel savings are negligible compared to the cost of the wear and tear on the engine. As long as the engine is running, there is a film of oil protecting all moving parts. Engine off and that oil film starts draining into the sump. The constant stopping and starting multiplies the amount of wear on the crank shaft, bearings, cam shaft, guides, etc.
Old Oct 19, 2024 | 10:00 AM
W205C43PFL's Avatar
Agree, there is more wear on the starter, the engine, the engine mounts, the starter battery, etc.
Old Oct 19, 2024 | 10:17 AM
4thDoctorWhoFan's Avatar
GLE450 SUV
How is it permanently disabled?
Old Oct 19, 2024 | 10:27 AM
JettaRed's Avatar
Veteran: Army
There are a couple of ways. You can't do it from XENTRY but need to use one of the other programming tools. I don't know how to do it, but @BenzNinja can do it such that it remembers the last setting, either on or off. In my case, before I became familiar with BenzNinja, I purchased two dongles from Mid City Engineering to do the same. I have two cars, so my expense was doubled. I could have put that money toward a BenzNinja Club membership or SDS components if I had known.
The dongles worked, but they were essentially single use, whereas the BenzNinja Club membership has been immensely more valuable.
Old Oct 19, 2024 | 11:10 AM
streborx's Avatar
Top Answer: 1
G550
There are a couple of forum threads on how to disable start/stop, among them:
https://mbworld.org/forums/e-class-w...ii-reader.html describes how to do it with the Launch OBD scanner.
https://mbworld.org/forums/mercedes-...o-dummies.html describes how to do it with Xentry.
I used the Launch scanner method, but prior to that drove for several months with the battery charging sensor disconnected (effective, but admittedly a hack).
Further to the OP's inquiry, there are a variety of parameters that enable or suspend the start/stop function. One is the charge state of the starter battery. There's a current sensor (the one I disconnected) attached to the battery's negative terminal that measures charging current. If the alternator is applying a substantial charge current to the battery -- for instance, after many start/stop cycles in bumper to bumper traffic on the LA freeway -- start/stop is suspended so that the car doesn't stop and then have insufficient battery capacity to start.
JettaRed's comments above are correct -- start/stop scores fuel economy points for manufacturers and is not beneficial to the majority of drivers.
Old Oct 19, 2024 | 01:50 PM
W205C43PFL's Avatar
https://mbworld.org/forums/s-class-w...tart-stop.html
Then there is also this, unplugging the battery sensor, don't recommend it because the car checks the voltage real time with this sensor so if unplugging it, the alternator will run at full all the time and also RPMs at idle will be slightly higher:
https://mbworld.org/forums/c-class-w...tart-stop.html
https://mbworld.org/forums/c-class-w...ngle-plug.html
Old Oct 19, 2024 | 01:59 PM
mikapen's Avatar
It's not a "novelty" for the "uninformed." It's a strategy that manufacturers have adopted to reduce Fed fines. You might say that the bureaucrats who bring us unreasonable CAFE standards are the "Uninformed."
Fuel savings can actually be significant. They definitely are significant on the EPA test cycle, which is why manufacturers use it.
Start/stop with an ISG doesn't involve any gears, and the tranny doesn't see any stress because it's not involved.
Motor oil's film strength has improved, and interior tolerances are tighter, so there is less drainback and therefore the wear issue is reduced on engines specifying 0WXX or 5WXX. So it's less of an issue than ones specifying 15WXX or 20WXX. Days gone by.
I haven't seen any current data on newer engines that show results similar to decade-old data that shows 5-30% increased wear due to drainback. Have you?
The only thing that's clear from a variety of forums, is that Start /Stop is generally despised (mostley by non-ISG owners).
And that several folks have paid to disable it.
I seldom keep modern cars over 100k miles, so their potential reduction in engine life from 280,000 miles to 220,000 miles isn't an issue for me. I'd add zinc additives if I wanted to be kinder to my bearings.
Plus, my passengers can't tell me when it Starts or Stops. If it were obtrusive, I might be more concerned.
It's a personal preference.
Old Oct 19, 2024 | 04:15 PM
streborx's Avatar
Top Answer: 1
G550
As I confessed, it was a hack! I never noticed any difference in alternator or idle RPM behavior, but always did get a battery sensor fault when running an OBD scan. I'm glad now to have start stop legitimately coded off.
Old Oct 19, 2024 | 06:22 PM
W205C43PFL's Avatar
I see, if it works for you that is good
Old Oct 19, 2024 | 06:57 PM
JettaRed's Avatar
Veteran: Army
Originally Posted by mikapen
It's not a "novelty" for the "uninformed." It's a strategy that manufacturers have adopted to reduce Fed fines. ...
All good points. But any additional wear is a negative for me, even 5%.
One of the primary reasons I disabled mine was, prior to knowing the potential for extra wear, was my wife absolutely hated it and asked if something could be done. For a car guy like me, that was being given $5 and let loose in the penny candy store. I always had a nagging fear that the car wouldn't start and be ready to immediately go when pulling out into heavy traffic from a side street. But, as you said, it's a personal preference.
Old Oct 19, 2024 | 08:28 PM
mikapen's Avatar
@JettaRed what's your car? With or without ISG?
Old Oct 19, 2024 | 11:21 PM
JettaRed's Avatar
Veteran: Army
Both of my cars are without ISG.
2014 C350
2015 SL400
Old Oct 20, 2024 | 08:50 AM
W205C43PFL's Avatar
2014 C350
2015 SL400
Vehicles with ISG are smoother for sure when it comes to start/stop due to the design of it. By the way, saw this video, talks about hybrids but not just mild-hybrids, cool to see the engineering behind it:
Old Oct 20, 2024 | 09:17 AM
wildta's Avatar
GLE 580
Vehicles with ISG are smoother for sure when it comes to start/stop due to the design of it. By the way, saw this video, talks about hybrids but not just mild-hybrids, cool to see the engineering behind it: https://www.youtube.com/watch?v=3eC5FFoCq4s
After watching that video, I felt it was a bit of a clickbait and a product plug for issues that don't exist anymore. Did you feel that? I still like his videos because of the explanations though.
Old Oct 20, 2024 | 09:27 AM
W205C43PFL's Avatar
I admit I haven't watched the video yet but his videos were usually legit, since it just showed up in my subscriptions I thought I would share it as it corresponds with the topic being discussed. If I do watch it and turns out in a way of how you described it, that would be disappointing.
Old Oct 20, 2024 | 09:28 AM
streborx's Avatar
Top Answer: 1
G550
For me, the smoother start/stop performance of an ISG equipped vehicle is not worth the consequences of mild hybrid malfunctioning. Mild hybrid systems are entirely nonessential to the propulsion of the vehicle under conventional ICE power, yet are designed to cripple the car immediately when/if anything goes amiss, or even becomes indeterminant. This is a safety issue, not a fuel efficiency issue. An ISG/mild hybrid equipped vehicle should at least allow a driveable range and/or time before bricking it. Maybe only 1% of ISG vehicles experience problems, but IMO that's 1% too many.
Old Oct 20, 2024 | 12:39 PM
mikapen's Avatar
Yes, IMO he's become a shill for the most recent "event' he attended.
He's pretty reliable at that, so he gets plenty of invites. He is either not aware of others who provide the same or better services /features, or hides that info.
He makes his diagrams overly complicated so they're difficult to understand. Plus in many cases they're just wrong.
I quit watching him about 2 years ago.
He's in my Scotty Kilmer category.
Old Oct 20, 2024 | 12:40 PM
W205C43PFL's Avatar
The problem is in MB's setup, it also drives the water pump (if I recalled correctly) so you can't run the vehicle without the mild hybrid system working.
Old Oct 20, 2024 | 12:59 PM
mikapen's Avatar
I think we have a nomenclature problem here. A mild hybrid does not provide electric-only driving. None do.
The ISG provides an entirely different set of advantages.
It provides a 48v system that eliminates belt-driven accessories such as water pump, AC compressor, and suspensions. It also gives immediate throttle response by adding 180 lb-ft of torque, and regenerative braking that saves brake wear
I don't remember any complaints about a failed ISG on the forum.
It makes the car feel like a naturally aspirated car.
And an almost imperceptible start / stop feature.
Old Oct 21, 2024 | 09:00 AM
streborx's Avatar
Top Answer: 1
G550
I don't believe anywhere in my comments is there an inference that a mild hybrid provides electric only driving. I am aware that it provides initial propulsion and engine startup under certain conditions, and I expect the start/stop function is considerably smoother. However, I doubt that the small size of the mild hybrid battery can also power AC, water pump and other conventionally belt driven devices. Does it also drive the alternator to charge the 12 volt battery? The ISG itself might well be a highly reliable device, but this forum is well represented with misery regarding the 48 volt system. This is where I object to the mild hybrid implementation -- a malfunction with the 48 volt battery, its charging system or its cooling system shouldn't make the car immediately undriveable and require flat-bedding to a dealer for repair. For me, this would involve a truck making 2 roundtrips of 300 miles each way. I am amused however by inquiries about 48 volt battery charging. Most advice is that because it's charged by regenerative braking, you have to drive the car to charge it. In other words, go burn off a couple gallons of fuel so you can save a couple gallons thereafter.
Old Oct 21, 2024 | 09:23 AM
W205C43PFL's Avatar
Yup, I have reasons to believe the ISG is reliable, the main issue was the 48V issues and the battery itself that affected not just MB but competitors as well. By the way, since we are talking about ISG, it reminded me of this video:
Old Oct 21, 2024 | 11:00 AM
PeteInGilroy's Avatar
'25 MB GLE 450, w/airmatic
If you disable the auto stop/start, are you also disabling the hybrid that adds more torque?
