GLE Navigation and HUD issues
I own GLE year 2021, 49000km
In 2023 I was having problem with auto driving mode because of blurry camera, few weeks after I was having Anti Theift error and got PCB replaced
After those 2 error here are another ones which are unsolved and looking for your feedback if anyone had similar issues
1. HUD display is moving automatically to position 0 after setting it to position lower (-2) after restart of car
2. Navigation is moving automatically up down left right without touching it and of course cant be used for driving
Please help as I assume that Merc service dealer will not have proper solution
too many problems with such expensive car
Thank you
For your HUD, try creating a new driver profile and setting up the HUD position to see if it saves it with a new profile, just as a test.
For the navigation issue, no other screens have this weird movement issue?
For navigation moving I was already at Mercedes dealer, they just did update and it worked fine for 2 weeks, after that, problem appeared again.
Only navigation has weird movement, when you are in other menus like telephone, radio, settings etc all works fine. What I have also noticed is that system drop out message “New gesture detected” few times a day.
https://m.youtube.com/watch?v=1s9zBZCYcqA
I did test related to “wildta” message and I have disabled Interior assistant and navigation starts to work as it should. It so weird that Interior assistant is making problems to navigation. I will keep it off as it not represent any huge benefit for me but in long run it should work with turned on. Probably we are having some software conflict. Is there any with similar experience?
thank you
thank you
I'm writing from Hungary. My car is serviced at one of the largest Mercedes dealers in Hungary, still under warranty. But unfortunately they don't know a lot of things. It's terrible!
(Sorry, I'm using Google Translate)
Please help!
1. How can I set the radio to not play automatically when I start my car?
2. What audio codec should I use so that multimedia files have sound (avi, mkv, mp4, etc)?
Please direct me to the appropriate topic.
Thank you very much!
Please help!
- If you have your radio off/muted before turning off the car, the next time you turn on your car, it will remember that it was muted/off. It used the last setting.
- MP3 is most common. I just use Spotify and stream it via Android Auto.
2. MP3 is most common. I just use Spotify and stream it via Android Auto.
1. So, is there no setting (in the Dealer Menu or some other secret menu) where you can set the radio to play at volume '1' or volume '0' by default?
2. I wasn't thinking of music files in this case, but video files.....
Many thanx for your help!
- You could try playing with the menu shown in the 5min mark of this video
- Sorry I can't help with that.
Did they ever find a solution for you?
