2024 GLE450 Active Parking Assist and PARKTRONIC Inoperative
Old Jan 18, 2025 | 09:40 AM
Ryanville's Avatar
2024 GLE 450
Hi fellow GLE owners.
About 50% of the time when I start my car and shift into Drive or Reverse I get these warnings. It’s really annoying and quite embarrassing when others are in the car.
Once I start driving it goes away and all systems appear to work normally. Sometimes however I’ll get these inoperative warnings while I’m driving.
I’ve taken my car to the dealer 3 times for this and they always just do a “software update”, it clears up the issue for about a week but then it all comes back.
Has anyone experienced this and did they find a fix? Appreciate any help thank you.
Old Jan 18, 2025 | 10:30 AM
W205C43PFL's Avatar
Might be a tire pressure issue: https://mbworld.org/forums/s-class-w...down-help.html
Old Jan 18, 2025 | 10:36 AM
Ryanville's Avatar
2024 GLE 450
Interesting, thanks for sharing. My tire pressure is within normal range but it’s been really cold where I live in Canada. I’ll try topping them up a little bit and see what happens.
Old Jan 18, 2025 | 10:41 AM
W205C43PFL's Avatar
You're welcome : )
Hopefully that fixes it, might explain why after driving the issue fix itself but after sitting overnight, the first drive, the error messages comes back up as you know, driving increases the tire pressure as air heats up.
Use the cold tire pressures listed on the fuel cap, if you have winter tires, use the M+S values.
Once done press ok on the tire pressure screen and select accept as new reference values.
Old Jan 19, 2025 | 12:23 PM
parato's Avatar
2024 GLE 450e
You're welcome : )
Are you sure that's the recommended tire pressure? My 450e is higher. Have you checked the tire placard located on the driver's side door jamb?
Old Jan 19, 2025 | 12:59 PM
mikapen's Avatar
That's the wrong place to see the recommendations for tire pressures. Those pressures are Tire Specific, as required by the Feds.
MB goes a step further and puts their Car Specific pressures on the gas flap.
Gas flap pressures are the ones to use, at least as a starting point.
Old Jan 19, 2025 | 08:11 PM
W205C43PFL's Avatar
As mentioned, use the fuel cap pressures, measure when cold.
Old Jan 20, 2025 | 12:26 AM
bkushner's Avatar
2024 GLE 580
I get it once in awhile surely not as frequently as you. I'd say maybe 3-5 times in 8 months.
Old Jan 20, 2025 | 11:13 AM
Ryanville's Avatar
2024 GLE 450
do you notice any correlation between the error and tire pressure? Because it’s an intermittent issue it’s tough replicating at the dealer so I don’t think they really do much when they tell me they’ve “updated the software”. Not sure how they can update the software 3 times.
Old Jan 20, 2025 | 04:41 PM
mikapen's Avatar
Have you reset your TPMS monitor?
Old Jan 26, 2025 | 09:10 AM
Ryanville's Avatar
2024 GLE 450
Just sharing an update, I’ve topped up my tire pressure and reset values on the system and haven’t had the error message pop up again. Hopefully this was the fix, thanks for all the help!
Old Jan 26, 2025 | 09:24 AM
W205C43PFL's Avatar
That is good to hear, might indeed have to do with the software glitch that was discussed.
