Permanent battery maintainer pigtail
Old Feb 23, 2026 | 02:31 PM
notlimahrelyt's Avatar
2014 C300 Sport / 2022 GLE 450
Has anyone put a pigtail on for a battery maintainer for easy connection? I had done this on my c300 when the battery was located under the hood, but since the battery on the gle is located under the driver seat and I just have the positive terminal post under the hood, but unsure how to set this up.
2022 GLE 450
Old Feb 23, 2026 | 03:00 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
The terminal under the hood will still work. All you really need is an always on circuit.
Old Feb 23, 2026 | 06:30 PM
streborx's Avatar
Top Answer: 1
G550
The terminal under the hood is the best and easiest point to access for charging. The charger's + (red) terminal attaches to it. The negative - (black) charger lead can attach to any bolt that's anchored electrically to the car's chassis. There should be existing forum threads describing pigtail installation. I think I posted my installation a few years back.
Old Feb 23, 2026 | 06:48 PM
if you could find it and link me that would be awesome. I’m not familiar with how the positive post is installed and how id connect the pigtail to it
Old Feb 23, 2026 | 09:54 PM
streborx's Avatar
Top Answer: 1
G550
https://mbworld.org/forums/g-class-w...onnection.html
Your battery configuration is likely different, but this should provide you the basics.
Old Feb 24, 2026 | 06:42 AM
fun33's Avatar
2017 550SL - 2018 560S
CTEK Cable 2026 GLE
My MB dealer installed this for free. Took about 10 minutes. I supplied the CTEK cable.
Old Feb 24, 2026 | 09:08 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
I may be 100% (or more) wrong. We have a charger port on our Sprinter to keep it plugged into a maintainer long term. I was old that on my E's or GLS it is not really plausible as I would want the hood UP during a battery maintainace time frame (the Sprinter sits in our driveay). Maybe I am wrong - but, even with a port you would still want the hood up.
Old Feb 24, 2026 | 09:09 AM
North Orlando?
Old Feb 25, 2026 | 07:11 AM
fun33's Avatar
I purchased my 2026 GLE from this dealer. The dealer installed the pigtale when I brought the car in for service 2 weeks after I purchased it. Fields Motorcars in Lakeland. If you go to Fields, you need to bring your own cable, and I am sure they will charge you to install it (especially if you did not purchase your car from them), but the install only takes @ 15 minutes.
Old Feb 25, 2026 | 07:15 AM
fun33's Avatar
With my setup, as shown in the photo, I connect another 8-foot-long CTEK cable to the permanently mounted cable the dealer installed. I can charge with the hood up or down; it makes no difference.
Old Feb 25, 2026 | 08:29 AM
streborx's Avatar
Top Answer: 1
G550
An extension cable works well, especially with a wall mount battery maintainer such as the Noco 1A unit. I avoid running an AC power cord under the hood where it might get pinched.
Old Feb 27, 2026 | 11:46 AM
cosmobenz's Avatar
2017 MB GLC300 & 2020 GLE350
Would anyone happen to have a photo of the pigtail installed on a 2021 GLE350? Particularly the POS cable tied in under the square black box? It's going to have to be a DIY job since dealer won't touch it!
Old Feb 27, 2026 | 12:58 PM
wildta's Avatar
GLE 580
https://mbworld.org/forums/gle-class...ads-guide.html
Old Feb 27, 2026 | 01:01 PM
wildta's Avatar
GLE 580
See here:
