GLE Class (W166) Produced 2015-2019
Apple Carplay with Iphone 5S
Old Apr 27, 2016 | 07:54 PM
mkspear32's Avatar
GLE 350 and ML350
Not sure what I am doing wrong here hopefully someone more knowledgeable can help. I just took delivery of a 2016 GLE 350 and it has carplay which works with my wife's Iphone 6sPlus but it will initially hook up to my 5s then disconnects saying that no carplay device is attached. I have siri turned on which I found is required for both phones. I routed a route on my 5s and plugged in the firewire and it hooked up and i chose the route and it started to work then disconnected. Frustrating. Any input will be most appreciated.
TIA
Old Apr 28, 2016 | 04:37 PM
johnnyderm's Avatar
Soon: 2020 G63 Currently: 2016 GLE63 SUV + 97 F250HD, Before: 2013 G550, Range Rover Sport, 1984 CJ7
Do you have the latest iphone update installed?
Old Apr 28, 2016 | 04:40 PM
mkspear32's Avatar
GLE 350 and ML350
Yes I do, ISO 9.3.1. I am about out of ideas on this thing. I would sure like to be able to use it after spending my money on it. Seems like a very nice app to have.
Mike
Old Apr 28, 2016 | 05:08 PM
johnnyderm's Avatar
It's just ok. You might use it a few times to humor yourself - but then you willl use the regular system 100% of the time unless impressing a friend. There's only a few apps and limited functionality. It's ok. Consider it something to look foeward to once it gets work ok.
At least you figured it is your iphone that is the problem The 7 comes out soon so upgrade! Or upgrade now :-)
Old Jun 2, 2016 | 12:37 PM
ilumo's Avatar
Mercedes GLS 450
No problems with 5s and 9.3.2 iOS version. also I love it. Just for the maps alone. it's LIGHTyears better than any other incar nav, well atleast from bmw,audi,merc,LR, etc. haven't tried tesla yet.
Old Jun 5, 2016 | 10:58 AM
BACnMercedes's Avatar
19 E63s, ‘24SQ8, wanting another gas guzzling V8
Did you get it to work?
Originally mine found my wife's s6 plus, then after about a week, it never would again (I use a samsung S5). I had to delete the phone from the car and then delete the car from the phone a couple of times and now it connects everytime without a problem.
Good luck.
Old Jun 5, 2016 | 11:00 AM
mkspear32's Avatar
GLE 350 and ML350
Good luck.
No I'll try what you did. Thank you!
Old Jun 6, 2016 | 02:58 PM
BE9872's Avatar
2016 GLE 350
My wife has an iPhone 5S and she does not experience any of the issues you've outlined here. I wonder if it may not be a phone issue.
I love Apple CarPlay and use it all the time. It's my goto app for navigation and music. I listen to XM quite a bit and have found that I can still use CarPlay while listening to XM, but have to use the steering wheel controls to change the stations, not a big deal.
I would like to believe that CarPlay will improve as Apple releases new versions of iOS so my infotainment experience can actually get better without having to buy a new car. There are two main things I don't like about CarPlay navigation. The first is that Apple doesn't announce the next turn far enough in advance. The second is that they have this blue line that shows you the path they want you to follow. That blue line is just too wide making it difficult to follow on occasions.
Other than that I love it, and can't wait for the next update.
Well, I said 2 things about the navigation bug me, but there are 2 other things I don't like as well. The app ecosystem is a lacking and you can't rearrange the apps on the screen.
Old Jun 8, 2016 | 08:52 AM
DHarris's Avatar
2013 X5 5.0 M sport
My Lunar Blue GlE 450 just came in. Currently deciding if I want to take it for wait about 10 weeks for a Brilliant Blue 43.
While going through the build sheet, I see no mention of CarPlay. How do I tell if the car has it? It should be listed, shouldn't it?
Thanks.
Old Jun 8, 2016 | 09:05 AM
mkspear32's Avatar
GLE 350 and ML350
Yes, my GLE350 shows car play on the build sheet. Try plugging in you iPhone with the USB cable and you'll know right away. You should have it.
Old Jun 8, 2016 | 09:22 AM
DHarris's Avatar
2013 X5 5.0 M sport
I'll try to have my dealer give it a shot today and let me know. I attached the build sheet here. Where should it have CarPlay listed? It's supposed to be standard, correct?
Also, need to decide on the color today. What're everyone's thoughts on the Lunar vs. the Brilliant, which is on the C coupes next to it.
Thanks again!
Old Jun 8, 2016 | 03:10 PM
mkspear32's Avatar
GLE 350 and ML350
Car play does not show up on the window sticker, but the dealer build sheet does show it, ask them to pull up the order for your car and you can verify it is installed.
Awesome car you have! Congratulations!
Old Jun 8, 2016 | 05:07 PM
DHarris's Avatar
2013 X5 5.0 M sport
Thanks! My dealer is looking into it. Still waffling between the blues but the Lunar looks better than I thought it would, may stick with it.
I'll posture pics if I end up taking it.
Old Jun 8, 2016 | 08:05 PM
eric1972's Avatar
2016 Mercedes-Benz GLE400, 2012 Honda Fit, 2011 BMW R1200R, 2009 Audi S4
If you can take a look at the sticker on the side of the driver-side door to see the manufacturing date, if it's made after Jan. 8 or 9 this year, then it's likely to have Carplay standard, as others have noted on this board.
Old Jun 9, 2016 | 02:21 PM
mkspear32's Avatar
GLE 350 and ML350
Active Suspension
Actually only active curve assist is available on the GLE 350 4M, not active suspension. I sure wish it was though.
