GLE Class (W166) Produced 2015-2019
2016 GLE350 Hitch
Old Aug 7, 2016 | 10:32 PM
cupertino's Avatar
2016 GLE350 2014 E350 Sport
2016 GLE350 Hitch
Hi Guys,
I have a 2016 GLE350 without active curve suspension. And I want to add a hitch so I can install bicycle rack.
Dealer gave me these part numbers
166-310-02-00, cross member - $1270.00
166-310-01-18, Longitudinal member - $411.73
166-310-02-18, Longitudinal member - $411.73
Parts alone are $2093.46 before installation.
Any suggestions?
Thank
Old Aug 8, 2016 | 03:50 PM
BACnMercedes's Avatar
19 E63s, ‘24SQ8, wanting another gas guzzling V8
Here is a little help.
https://mbworld.org/forums/gle-class...ler-hitch.html
https://mbworld.org/forums/gle-class...their-gle.html
That's what I found with a quick search. I'm sure there might be others with some more info or advice if you ask on their threads.
Good luck.
Old Aug 8, 2016 | 11:46 PM
fabbrisd1's Avatar
A gaggle of MB's
Sure - we just had a Curt hitch installed on a GLE - no wiring - at UHaul. Total price installed was $318.
There is a small "noise" vibration in the rear after that install - my tech's will put it up on a rack in the morning to track that down.
Old Aug 19, 2016 | 12:12 AM
cupertino's Avatar
A local store, "Rack N Road Car Racks" in San Jose told me that after market hitch like etrailer or hidden hitch will void the factory warranty.
Do you guys know if this is valid statement ?
Old Aug 19, 2016 | 12:49 AM
skw's Avatar
skw
2019 GLS450
Well there's a misleading blanket statement. So they're saying that if you take it in for the wipers not working, that the warranty will be denied because you have an aftermarket hitch installed? Of course not!
Installing an aftermarket part does not unilaterally void your vehicle's warranty. However, a warranty claim can be denied if a part fails due to the whatever you installed. For example, you install aftermarket lowering springs and a week later, the driver's window stops working. One thing has nothing to do with the other. However, let's say the shocks prematurely wear out, then that can attributed to the springs you installed.
