Further proof that our gear selectors are the spawn of Satan
OK, perhaps my headline is a bit over the top. But one of the key frustrations I have had with the GLE is how the transmission does not shift into "park" automatically when you turn the vehicle off. Now Consumer Reports is fighting back against these transmissions as well:
"We are also now deducting additional points from the Overall Score if a tested vehicle does not automatically return to Park or engage the parking brake when the engine is shut off."
On more than one occasion, I have the car off and stayed in it to finish a call or do some paperwork, only to look up and find myself starting to roll across the lot. When I bring it up to Mercedes, they look at me like I have three heads.
Guess I've either shifted to park or opened the door prior to turning the vehicle off and never encountered it.
Good to know that it could happen though, especially on a sloped area. The potential exists for a serious injury.
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (for sale)
Having said that, I do agree that we should have this feature. Since the technology is already here, there's no reason not to implement this additional safety feature.
It sounds like you're used to your car automatically shifting into Park when you shut off the engine. Never having had a car that did that, I can't miss what I've never had. I instinctively keep my foot on the brake until I manually shift into Park. It's not something I have to think about or could ever forget, because I've been doing it since I first learned how to drive. Having the car shift into Neutral when you shut off the engine and Park when you open the door, are already two new features for me.
I'm sure part of my problem is that I have multiple cars, the Mercedes has the least intuitive system of any of them. I'm sure another part of the problem is that I have previously owned two other "keyless" cars that shifted into park when turned off, so that is the habit I developed. I'm sure a third part of the problem is that I'm getting older by the day.
Jeep (And some lawyers) can problably chip in here. the not so intuitive gear selector in some 14 and 15 models actually killed someone when it rolled back (crushing the StarTrek actor), forcing a rather large recall...
However...The GLE (On mine) Sets the parking brake when I turn the ignition off.
Jeep (And some lawyers) can probably chip in here. the not so intuitive gear selector in some 14 and 15 models actually killed someone when it rolled back (crushing the StarTrek actor), forcing a rather large recall...
That couldn't happen with MB because the car would shift into Park as soon as the door was opened.
Yours sets the parking brake? Does it also shift into Neutral if it was previously in Drive or Reverse?
The following 2 users liked this post by nookie:
GLE43_Sube (03-02-2017),
OtherCarIsAJet (03-05-2017)
the warning about engine off and shift to neutral is in the manual. it would be interesting to understand why a shift to park doesn't occur. that said, i have owned standard trans vehicles all my life and it was always up to the driver to make sure the trans was locked down before you left the vehicle (as it was with auto trans before the electro-shift movement).
i think it shows that we are all starting to rely on tech more than we should. i'm trying to get my kids to use tech as a tool and not a be all, end all. right!
pls refer to above post
So I retract my statement that the onboard manual is idiotic, and replace it with not having access to the info other than in the car is idiotic.
2017 GLE 350 SUV Premium 3
"...not having access to the info other than in the car is idiotic."
You can download a pdf of all the manuals here:
https://www.mbusa.com/mercedes/servi...&class=M-Class
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
mine, where i said too much current reliance on tech. nice and slick to have e-manuals, unless you can't get to the e-manual.
buy a new computer lately? no paper! all good as long as the thing fires up. else, hope you have the old pc to get a download of a manual for the new pc.
Just like the industry adopted standards with traditional automatic transmissions, they are all lining up with the new transmissions. The only exceptions I have experienced are with Mercedes and FCA vehicles. That lack of following the standard (shifting into park when the vehicle is turned off) is what will cause issues.
Again, I drive a lot of cars. I have 7 myself and travel a lot, so I'm in rentals all the time. So perhaps that is why the transmission in the GLE catches me off guard.
I think what's not "intuitive" about the MB is that PARK initiation is a completely separate button. On conventional transmissions, it's all the same lever. I think if they had the option to push the lever up into a "further" up position (think cruise control) that would put it into park, that would at least be intuitive.
Ours has rolled a couple of times as well, when I forget to put it in park. Rolls until the door is opened...
the problem, i think is with the self-centering stalk. Slick, but not wholly needed imho. a static 4 position stalk would avoid the owner's manual warning, and this thread. but then again it would block some of the cluster, etc. that said, has anyone driven a new MDX. NFW!
