Correct Tire Pressure
Old Aug 25, 2009 | 08:22 PM
F18BEN's Avatar
Veteran: Army
2026 BMW 550e X DRIVE, 2024 GLE 450e SUV
I just got a message that says "Correct Tire Pressure". Does it mean it's correct or does it mean I need to correct it? Thanks , Frank
Old Aug 25, 2009 | 09:27 PM
F18BEN's Avatar
Veteran: Army
correct tire pressure
I found my answer:
The tire inflation pressure is too low in at least one tire.
or
The tire inflation pressures of the individual tires differ from
each other significantly.
The tire inflation pressure values are shown in the
multifunction display.
X Check and correct tire inflation pressure as required
(Y page 221).
X Restart the Advanced TMPS (Y page 226).
Old Aug 26, 2009 | 08:39 AM
NYCGLK's Avatar
GLK 350 / Porsche 993
cool thanks, how much was your tire pressure off? and was it one tire? all 4?
Old Aug 26, 2009 | 09:52 AM
F18BEN's Avatar
Veteran: Army
I'm checking the pressure today and will let you know...Frank
Old Aug 26, 2009 | 12:00 PM
andyf0's Avatar
GLK350 4MATIC
Must be full moon. I also got a low pressure warning. Checking with warm tires gave me 32.5, 33, 33.5, and 34. Is there no gas station with free air these days? I really object to paying a dollar to top up my tires.
I intend to balance all 4 to 34 psi since I figure by the time I get to a gas station the tires will have warmed up a bit. Recommended for normal load is 33 psi all around for cold tires with up to +4 for hot tires.
Old Aug 26, 2009 | 12:53 PM
MB_Owner's Avatar
M-B GLE, Porsche 911 Turbo, Porsche Boxster (spouse)
Use the electric pump provided with the GLK to inflate the spare. Let the vehicle sit overnight then use a quality gauge to set the pressures on all four before the morning sun has a chance to start warming up any of the tires.
Last, reset the TPMS per pp. 226 of the Owner's Manual.
Old Aug 26, 2009 | 03:01 PM
NYCGLK's Avatar
+1, the pump actually works really well.
Old Aug 26, 2009 | 04:08 PM
F18BEN's Avatar
Veteran: Army
Just checked my pressure
My tires were about the same as Andys. It wasn't off by more than a pound on any tire. I just now evened them all out at 33 all around. The warning only came on last night when I pulled into my garage. It was ok this morning.
Frank
Old Aug 26, 2009 | 05:44 PM
NYCGLK's Avatar
So seems that TPMS is pretty sensitive, I wonder if it goes off when cooler temps in winter come, and tire pressure decreases. I thought I read it doesn't work in winter, but I could have read it in my dream.
Old Aug 26, 2009 | 05:50 PM
andyf0's Avatar
GLK350 4MATIC
What pump? Where is it?
I do have a standalone electric pump but it makes so much noise and takes a long time.
Old Aug 26, 2009 | 06:59 PM
NYCGLK's Avatar
left side in the trunk under the lining, where the tools are
Old Aug 26, 2009 | 07:19 PM
hhughes1's Avatar
2013 Chevy 427 Torch Red
just a reminder that rec pressure for 20" is 35f/39r
Old Aug 26, 2009 | 07:22 PM
andyf0's Avatar
GLK350 4MATIC
35x39 is for fully loaded. 33x33 is normal load. It's on the inside of the gas cap door.
Old Aug 26, 2009 | 09:15 PM
PIETROD's Avatar
08 R32, 2010GLK
Remember all to reset your tire pressure baseline once you put air in you tires or it will never know new pressure starting point is. This is done via service menu options on the dash.
Old Aug 26, 2009 | 09:46 PM
F18BEN's Avatar
Veteran: Army
Thank you I already forgot..... Frank
Old Aug 28, 2009 | 09:55 PM
NYCGLK's Avatar
hahah warning too
Weather got colder in the area and one side is 31.5 and the other side is 30.5.
Old Aug 29, 2009 | 05:53 PM
Kbach's Avatar
GLS550
Something weird is going on. I just got the same warning pulling into the garage today. Guess I'll top them off in the morning.
Old Oct 9, 2009 | 10:37 PM
EnigmaAW's Avatar
2021 G63
the last 2 weeks i have also been getting the "correct tire pressure", when i turn the car off and i thought the TPMS was telling me the pressure was "CORRECT". with all the rain houston got today, i tried to avoid a huge puddle and must of hit a offset is the road......BANG!!! i thought i killed my 22's. 5 minutes later the "low tire pressure" warning came on. i pulled over and checked all the wheels and they seemed fine? i'm guessing i was low in a tire and hitting the rough road maybe caused a bit of air to squeeze out tripping the warning?
Old Oct 16, 2009 | 07:47 PM
Schutzen's Avatar
2010 GLK
TPMS
I switched over from my summer tires/wheels to my Pirelli snow tires on 17" rims and decided to test out the Canadian "Run Flat Indicator"...indirect method using the change in rotational speed due to low tire pressure.
The USA system is superior because it uses direct pressure measurement from each tire. FYI...FMVSS 138 is the law in the USA. Canada has no similar CMVSS therefore the cheap system.
Anyhow, I set the tire pressures to 33 psi, reset the system, drove a short distance for "learning" and then kept dropping the pressure in one tire (left rear) and went for a short drive @ 60 km/h...
- 30 psi...no warning
- 26 psi...no warning
- 22 psi...no warning
- 20 psi...WARNING finally...the centre cluster went RED (Mars Attacks)
At least it works, although by the time it activated, 13 psi was lost.
Attached Thumbnails Correct Tire Pressure-photo2.jpg   Correct Tire Pressure-photo.jpg
Old Oct 17, 2009 | 11:55 PM
yualfred's Avatar
GLK 350 4matic
^ Thanks for sharing your test. I had all the pressure in 29-31 after 4 months and there was no warning.
Old Oct 21, 2009 | 09:14 PM
Burl's Avatar
Red GLK 350
Hey, don't you all have nitrogen in your tires from the factory? I was told by the service writer that if I had to put "air" in the tires I should come by the dealer and get the "air" replaced by nitrogen...what gives?
Old Oct 22, 2009 | 01:22 AM
Leslielp's Avatar
2020 CLA 250 4Matic Black
Damm that Mars attack looks so cool... I would love to be able to togle the background colour
Its interesting that even with individual tired sensors that you guys get in the USA they don't tell you which tire is at fault.
Old Oct 22, 2009 | 09:52 AM
yualfred's Avatar
GLK 350 4matic
Another way to try:
Leave your hand brake on and start to drive, MARS ATTACK....
