8 speakers in GLK350? or 6 speakers?
I realize this is OEM part but price of Amplifier alone is more than what I paid for my entire H/K sound system.
Base system (MSRP)
Front Door Upper $24.50
Front Door Lower $47.50
Front Center $124.00
Rear Door $82.00
H/K sound system (MSRP)
Front Door Upper $49.50
Front Door Lower $195.00
Front Center $142.00
Rear Door $244.00
Rear speaker Back $124.00
Woofer Back $540.00
Amplifier $1,720.00
1) W/o nav system W/o cd changer
2) Monitor W/o navigation
3) Disc Navigation
4) Amplifier
5) Amplifier Bracket
6) Inst pnl speaker W/o premium audio
7) Upper W/o premium audio Back
8) Lower W/o premium audio Back
9) W/o premium audio W/o premium audio Back
10) Rear speaker Back
11) Woofer Back
Base system (MSRP)
Rear Door $82.00
Rear Door $244.00
Woofer Back $540.00
Amplifier $1,720.00
3) Disc Navigation
4) Amplifier
11) Woofer Back
I have the H/K sound system so I can’t confirm there is a front center speaker for standard sound system.
The description for the front center says “Inst pnl speaker W/o premium audio” and they have 2 different price for front center (Premium & Standard).
They do not list the size of the rear speakers. Does anybody know?
I am interested in the Infinity Kappa components, but I'm worried that new tweeters might not fit. Are the GLK tweeters in the A pillar? Does anybody know how big they are? The Kappa tweeter is 1".
Thanks.
If I want to send the FULL signal to the Cleansweep wouldn't I need both tweeters, both front woofers, and both rear woofers wired to it? That's a total of 6 inputs, so the JL wouldn't work.
Or can I skip the tweeters (if they are getting the same signal as the front woofers) or skip the rear speakers (if they are getting the same signal as the front woofers)?
I don't know how the head unit handles the signals to each speaker so I don't know what the right approach is.. thanks.
Edit: after further reading, I see the JL Cleansweep CL-SSI has 3-way summing described as:
"3-Way Mode:
In the 3-Way mode, the CL-SSI will sum
an OEM subwoofer or woofer signal (lowpass filtered) to a mid-bass or midrange signal
(bandpass filtered) and to a high frequency signal
(high-pass filtered), creating a two-channel,
full-range stereo output."
But I'm still not sure if the GLK speaker signals qualify as lowpass filtered, bandpass filtered, and highpass filtered. Help is appreciated.
For your information the stock speakers were made of extremely cheap parts : thin black paper cones with very small magnets and a plastic assembly.
To my surprise the rear speakers were NOT 2-ways. Only woofers, that's why they sounded this bad.
I placed the kappa 10.9T tweeters in the A pillars and they were very easy to fit. I just pulled of the plastic support inside the cover and the tweeters fitted right into the black foam underneath the cover.
I used the 60.9cs on the 4 doors (2-ways). Tight bass and crips highs.
I ended up going with Focal VR 165 components up front and the matching Focal CVX speakers in the rear and a 10" JL W3 in the back, which is built into the quarter panel area. Everything's powered by a JL XD 700/5. And I reluctantly bit the bullet and bought the Audison Bit One to handle the sound processing. It sounds great. I'd recommend all of these products.
Here is one pic of the JL 10" W3 without the grill installed. The carpet matches very closely but the flash exaggerates the discrepancy.
I would like to install the Infinity kappa 60.9CS like you did too. Would you post DIY and pic please? How do you take out the door panel and A pillar to install the speakers?
