Keyless go unlock & lock door when wash car
Does this happen to anyone or is my door so sensitive that the ground signal from my body is being transfer thru the water and into the handle area?
The lock/unlocking "button" is pressure sensitive, so when the high pressure water hits it, it will lock and unlock..
Does make sense, though; thanks!
You could unlock the vehicle by mistake if
the distance between the KEYLESS-GO key
and the vehicle is less than 3 ft (1 m) and:
- an exterior door handle is hit by a water
jet
or
- you clean an exterior door handle.
also, I just had a 2012 GLK loaner while my CLK was in the shop, and it had keyless entry with the start/stop button removed, so I don't think removal disables the locks.
BTW...do you guys know if the rubber thing has a sensor on it? I tried inserthing my finger and pushing it down with the key inside the car and it didn't start the engine.
Keyless Go ROCKS!
Wayne
The doors won't lock if you leave the key in the cup holder.
I've tried a this a few months ago, and it did lock the car. (The key's battery must be on it's way out).
I tried again today and it did not lock the car. The message on the display said it detected the key's inside the car and it won't lock the doors.
I've just changed the battery on the remote last week, probably that's why it works like the way it is now.
I am too love this Keyless Go feature.
i guess i shouldn't have the key in my pocket with washing the E.
Keyless Go ROCKS!
Wayne
I have remote control tailgate on my key fob (no Keyless Go).
Right... that's how forum's work!
