Iphone 5 bluetooth wont connect
Old May 17, 2014 | 05:10 PM
Mikephinney's Avatar
2012 C250
When I attempt to connect my iPhone 5 it asks for the 4 digit code on the phone, but the code never appears. Is there a setting I need to adjust. On my C250 the code pops right up. My parents GLK350 is what I'm having a problem with. Has Nav ipod cable in console. Thanks
Old May 18, 2014 | 08:18 AM
Gt. Dane's Avatar
GLK250 BT
Did you try turning off the code on the phone? I had no problem connecting mine.
Old May 18, 2014 | 09:10 AM
cindyclk's Avatar
I would start all over...open iphone ...be sure bluetooth is set on...leave phone on....start car...audio... search for phones...when it finds your iphone, enter a code...I set mine for 0000....go to phone...options ...bluetooth...devices (MB Bluetooth should appear)...open and enter same code...they should now be linked.
Update us on your progress.
Old May 18, 2014 | 02:22 PM
balticgreen's Avatar
2014 GLK250 BlueTEC, 2012 BMW 335is Conv.
There are two ways to do it. You can have the car search for the phone or have the phone search for the car. Whichever way you're doing it, try the other one. Both methods are in the user manual. Some people have success with one but not the other.
Old May 18, 2014 | 05:00 PM
fabbrisd1's Avatar
A gaggle of MB's
That's the point... his iPhone has not been linked from COMAND..
Old May 19, 2014 | 11:11 AM
LesF's Avatar
2014 glk 250BT (RIP, 3/1/17}, 2010 C300
if I remember correctly the code is your unlock code for the phone. And don't use the cable to pair the phone to the car, use only the bluetooth.
Old May 19, 2014 | 07:35 PM
cindyclk's Avatar
I don't believe so....you can make up any code when you pair them.
Old May 20, 2014 | 02:42 PM
bop11's Avatar
350 GLK, C280
Have yu reset the phone, Turn the phone off by holding the top button till it says off then slide to the left to turn it off. Now hold the top button for 20 seconds after you see the Apple to totally reset the operating system. Anytime something doesn't seem to work, that should be the first thing. You won't lose any info, but I have had my iPhone 5 hang on all sorts of stuff and only work after reset. I think they learned this from Microsoft.
