Canadian friends
Old Sep 25, 2015 | 09:12 AM
bop11's Avatar
350 GLK, C280
Canadian friends
You guys up North have the cold experience, when it gets cold do your Nav screens turn purple until the car gets warm?
Old Sep 25, 2015 | 11:41 AM
ble2716's Avatar
Very very slow
I have a 2010-GLK and have not seen the Nav screen turns purple yet.
Old Sep 25, 2015 | 12:24 PM
dbldpr's Avatar
Veteran: Navy
Did you bring it in and the dealer told you it was normal.. If they did get it in writing. Then send it to MB headquarters.
Old Sep 26, 2015 | 11:51 AM
Cwdawson's Avatar
Fj cruiser 2014 GLK250
Never seen that yet, but then we've only seen to about -35 c so no real extreme cold as yet....
Old Sep 27, 2015 | 10:18 AM
Tate's Avatar
GLK350
Never happened to mine. Better to take it to the dealer.
Old Sep 27, 2015 | 11:55 AM
rshew's Avatar
2011 GLK 350 4matic
Never had purple screen. My GLK has been in -15 degrees Celsius.
Old Sep 27, 2015 | 08:20 PM
n8nu's Avatar
GLK 350
Yes, saw it last winter. A couple of nights it got to -40C or colder and my screen on my 2010 was purple until it warmed up.
Old Sep 28, 2015 | 09:07 AM
bop11's Avatar
350 GLK, C280
Thanks for the info. It works fine just tends to shade to a purple tinge until it warms up like n8nu said. Seems to be getting more prevalent. With 90,000 miles on the 2010, it is way out of warranty.
Old Apr 29, 2016 | 10:51 PM
Benz_Bougie's Avatar
2012 GLK350 AMG package
I've had the issue of it not working when it was extremely cold. Can't remember what message came up but back to normal after it was a bit warmer
Old May 2, 2016 | 05:38 PM
autoworrks320's Avatar
93 500e. 15 GLK 250
How much could they charge to replace it? Couple hundred?
Old Jul 14, 2017 | 01:27 PM
RNajarian's Avatar
Veteran: Air Force
2020 E 350; 2022 E450 Coupe; 2005 Porsche Cayenne; 1975 Porsche 911 Carrera 3.0
My old CLK did that, in 90 degree Weather
My old 2007 CLK with command did the same thing. Except in Warm weather. If I tapped the bezel around the command screen it would revert back to normal.
Sometimes it would go back and forth all by itself. I wasn't sure whether it was a bad battery causing some electrical gremlins or the screen going out. I ended up trading in the car before I found out.
Below is a photograph of what the purple screen look like
Old Jul 15, 2017 | 08:05 PM
mjhawkins2346's Avatar
2016 GLE300d 4Matic
I used to have that problem on some monitors when the connector in the back had one of the leads in the cable go high resistance. on me. My money is on one of the wires in the connector being right on the edge with the cold weather shrinking stuff - like copper as it does causing a connection to go high.
