2013 GLK 350 4x4 7G+ Transmission Issue!
In NA they say the service is due at 70k miles. My buddy who is a 30 year MB Master Tech here and all over the world, says 40k Miles. I'm glad we did.
Cause: Electrolytic corrosion exacerbated by moisture and road salt at the drain plug. According to MBUSA this could cause "catastrophic failure" of the transmission if the leak was not noticed, or the assembly just failed. The replacement transmission is $8k!
If you were going to purchase a certified preowned MB with this transmission of any mileage/age one might consider making sure the new "improved" pan is in place and the service is performed. If you have one now check it.
Don't they teach automotive engineers about electrolytic corrosion?
I don't know how to post pictures but I have several.
https://mbworld.org/forums/glk-class...id-change.html
Why doesn't MB use a non-metallic washer or a disposable heavy-duty plastic bolt??
The best or nothing?
I expected better from the engineers at Mercedes!
I'd wager that's more from a failure of the coating where the threaded insert is welded into the pan, and rust spreading under the paint around it.
I've not seen a bulletin or "updated pan" about this, but now i'm curious and will look. On the bright side, the pans are pretty cheap, and if this happens and you catch it before it breaks through, it's not a terrible fix, the pan has to come off for the service anyway.
