torque specs for control arms/sway bar links
First is your vehicle RWD or 4matic? Also, remember that any time you tighten/torque a bolt at the subframe for one of the control arm bushings, you need to have the vehicle at normal ride height with the weight of the vehicle on the suspension (on the ground, not on jack stands or a lift).
(RWD) Lower control arm (cross strut) to subframe M14x115 = 80Nm + 120 degrees
(RWD & 4matic) Lower control arm (cross strut) to subframe M14x120 = 120Nm + 180 degrees
(RWD) Lower control arm to spindle = 50Nm + 60 degrees
(4matic) Lower control arm to spindle = 50Nm + 90 degrees
(RWD) Torque strut to subframe M14x115 = 80Nm + 120 degrees
(RWD & 4matic) Torque strut to subframe M14x120 = 120Nm + 180 degrees
(RWD) Torque strut to spindle = 50Nm + 60 degrees
(4matic) Torque strut to spindle = 50Nm + 90 degrees
Front sway bar link to sway bar = 98Nm
Front sway bar to strut = 98Nm
#1 - Torque to 160Nm
#2 - Loosen 180 degrees
#3 - Torque to 120Nm
#4 - Tighten an additional 90 degrees
if you have any more questions, just send me a private message on here. I almost missed this one, sorry.
Mine only says 10.9 K + 2
