Life expectancy- GLK brakes (pads and rotors)??
i could easily handle the brake service, the write-up on this forim is great and I’ve done many brake jobs. I have a few questions;
1. Are the rotors considered wear items and replaced at the same time as pads?
2. What would the dealer estimate be?
3. Where is a good resource for OEM parts besides the dealer?
thanks in advance.
OJ
In a few decades of driving I have never had a vehicle go though pads this fast and I am used to replacing them at 70k miles or more. I was talking to a colleague at work today and she recently had to replace the front brakes on her nearly new GLE350 at just 12k miles.
I now have a few thousand miles on my ceramic pads and new rotors and I still see the cross hatching machine marks on the rotors indicating almost zero wear. Had I used Mercedes parts I am sure there would be visible wear. Furthermore, I have not washed the GLK in almost two weeks due to the weather and my wheels are still silver. With the OEM brakes the wheels would now be black. As far as I can tell there is slightly less initial bite with the ceramics and they require slightly more pedal pressure both of which are a small price to pay If knowing I will probably never need to change the brakes on this car and my wheels will never again be black with brake dust.
1) Yes, the rotors are a wear item and should be replaced at the same time as pads. If you have not changed the brake fluid then this is a good time.
2) Around here I understand the dealer price to be about $300 a wheel or about $1200 for front and back.
3) The dealers usually have online sites that will sell at a small discount. Google discount wholesale mercedes parts.
On a related note - I see that most places selling MB OEM parts are out of OEM rotors. Is there a story behind this?
Thanks again for the info. I love the satisfaction that comes from maintaining your own vehicle.
OJ
thanks in advance.
OJ
thanks
OJ
Picked up front and rear brake kits (rotors, pads, hardware, sensors) and brake fluid from IDParts. Did a few hours last night after work... Few hours today and should be done. Nothing crazy, pretty straight forward process. Expect to have either good impact or long breaker bar for those calliper carrier bolts
Dealer's estimate is about $1500CAD, all said and done ~ about 5 hours of labour + parts+ tax
Some pictures of my progress.
That's some serious wheel hub right here
I’ve yet to do the rears, only replaced the fronts about 25k miles ago due to some warpage and shaking on the OEM stuff the MB dealer did as part of the CPO deal.
My next set will be cross-drilled fronts and solid rears with Akebono pads all around and fresh DOT4 fluid. Just waiting on the brake wear sensor to light up...
Few min with a scotchpad disk would've saved 10 min of driving around and burning all that crap off before bedding pads in.
Old OEMs with new Front rotors
Front
Rear
Anyways, pads are bedded in, I'll check in 500 miles - should be fully set by then. So far no issues. The brake pedal is rock hard with engine off, a little squishy with engine running. Going to bleed again using "old-school" method but after doing multiple brake jobs on newer german cars (2011+) and talking to a local dealership mechanics I am not worried. All of them confirm that brake pedal WILL NOT be rock hard with engine ON. Even after actuating ABS module it would still feel a little spongy.
