1st Time GLK Buyer
Old Oct 4, 2020 | 12:20 PM
kcbusquets's Avatar
Mercedes GLK
1st Time GLK Buyer
Hello everyone,
I’m looking at buying a used 2010 Mercedes GLK 350 4MATIC. It was manufactured in Germany, has 128,000 miles & 1 owner who claims to have kept up with the maintenance, although they do not have records to prove. I am on the verge of getting it for $7500. I took it to the mechanic for the inspection and they couldn’t find any immediate issues with the engine or transmission. No leaks. Ran smooth as butter when I took it for a drive. Only the front shocks/struts need replacing soon.
I was hoping to get some feedback from anyone who has owned this model or a similar model. Has anyone had experience or seen this car get up to 200k miles or more?
Should I go for it? Or is this a money pit?
Any and all comments are appreciated
Old Oct 4, 2020 | 12:24 PM
kcbusquets's Avatar
Mercedes GLK
Sorry if I posted this thread in the wrong place. This is my first time using a site like this!
Old Oct 4, 2020 | 05:48 PM
karmikan's Avatar
GLC300 (mine) GLK250 (wife's)
Almost any10+ yr old car with 120K+ mi poses a risk. The downside risk for German luxury vehicles is simply huge if servicing at a dealership is anticipated. On the plus side, the GLK is built like a bank vault and some systems are fairly straightforward to fix. As you've probably figured out after reading posts on this site, complicated, expensive problems can crop up and the cost of parts can be eye-watering. Do you know a reputable indy with solid verifiable MB experience? Almost as important, can you DIY?
If the mechanic who inspected the car is experienced working on German/MB cars - great. If not I would take the car to an MB specialist and have a comprehensive inspection done. The absence of service/repair records is a bit of a red flag and I would investigate this further with the owner.
Good luck
Old Oct 5, 2020 | 09:24 AM
formerjeepguy's Avatar
2015 GLK350
The weak point on these is the 4matic system. Specifically the transfer case. Listen for a speed related whine coming from the front indicating the bearings going out. Repairs for the transfer case / front differential can easily approach the purchase price of the car.
Old Oct 5, 2020 | 11:44 AM
Mmr1's Avatar
2013 glk 350
With no maintenance records I’d probably pass, to me that means lack of maintenance, all mb owners know that records are important.
If you don’t have an independent mechanic I’d pass because a dealership will kill you on repairs.
Old Oct 6, 2020 | 09:50 AM
andreigbs's Avatar
GLK 250
Any car can be a money pit, especially German luxury brands.
I'd make sure I really trust the mechanic, otherwise he might be telling you one thing before you buy it and something quite different after. You wouldn't be the first.
I would also up my budget to $10k, that way you can find a more recent model with less miles. I'd be very wary of no history/records being available. Doesn't CarFax or Autocheck come up with anything? And before you purchase anything, you should see and drive at least a few of the ones you're looking at. Nothing is more helpful than comparing the same model back to back to back.
Good luck.
Old Oct 6, 2020 | 05:02 PM
NYCGLK's Avatar
GLK 350 / Porsche 993
Here is the noise of failing transfer case bearing.
https://photos.app.*******/gYztWBkDyjr1W9WY9
If you can wrench and have time and interest, sure can be good deal, but here is what I faced in 2020 after owning car since new....11 year 105k miles:
Idler pulley seized and melted shredding the belt. Easy job, but I was literally stranded (1 mile away from home tho).
Crank pulley failed...easy but requires muscle and special tool. At dealer 1k easy. I used OEM pulley, MB cost was stupid.
Transfer case bearing (noise above). Dealer will tell you to get new tranny. I don't know how much indy would charge. It's not easiest job. See here: https://mbworld.org/forums/glk-class...anny-diff.html
Next up is intake manifold a know issue, those start to fail from dirt build up. I'm getting 0521 code (no cel) and runs fine. I'm not in rush to replace this one yet. Will probably replace AOS and PCV pipes at that time.
Engine mounts start to fail (no big deal but you start getting vibration) after 60k miles, I replaced mine at 90k, and it's a PITA job on AWD.
Then you have reg. things to consider, tires, battery, transmission service, plugs. Wheels are most likely bent if 20s (not bad but not super straight either)
Waterpump and T-stat are also on my list.
Again this is on a car I have had since new and it still looks like new. So don't kid yourself about what you are buying. It's a 10 year old car.
Old Oct 6, 2020 | 05:08 PM
NYCGLK's Avatar
One more....you need front rotors every 20k miles due to warping if you used brakes. But that's like 45min job.
Old Oct 7, 2020 | 05:20 AM
GLK Super Fan's Avatar
GLK250 ML350
Idler pulley melted shredding the belt. Easy job, but I was literally stranded (1 mile away from home tho).
Next up is intake manifold a know issue, those start to fail from dirt build up. I'm getting 0521 code (no cel) and run runs fine. I'm not in rush to replace this one yet. Will probably replace AOS and PCV pipes at that time.
Omg... And plp still complaints about the diesel. Lol 🤣 Sounds like the diesel and gas has the same amount of problems
Old Oct 7, 2020 | 08:14 AM
NYCGLK's Avatar
My car is 11 years old and never had any issues for 10.5 years lol. M272 motor should be rock solid tho.
The only part that really sucks on this car is failing bearing in the TC but that will apply to pretty much every 4matic.
Diesel is likely to have all these problem on top of its own stuff stuff.
