Heater blower motor
Maybe try this to see if it is the issue. The brushes in my blower had lots of life left. There's a tab you have to press on to allow the blower assembly to rotate and drop out of the dashboard housing. Mark the blower's position before rotating and removal to ensure correct re installation. Unplug the wires first and reconnect them last. I found an inductor very close to the motor frame covered in carbon brush dust with the dust bridging over to the motor frame - the dust might have been the culprit, as it is conductive. (Did a study on this at work in electronic circuit boards years ago using a microscope. It's strange, but true how dust can be a conductor and short things out. Took the pics then, solved the issue). I moved the inductor a little bit away from the frame after cleaning, don't scratch its coating. Make sure the alcohol has completely evaporated before reinstalling, you don't want a fire!
I wrote about this previously with how-to steps, see if you can search it up, but this is the general procedure of what I did.
Best,
Steve
Personally, I'd use an electronic spray vs alcohol ... I use CRC Electronic spray (no, I'm not advertising or get a kickback
)https://www.fcpeuro.com/products/mer...tor-2128200708
