Engine ticking noise
Old Feb 23, 2024 | 01:16 AM
wclancy's Avatar
2013 Mercedes Benz Glk350
My recently acquired 2013 glk350 has a ticking noise from the engine. Don’t know if it’s a valve train issue or a noisy fuel injector
Old Feb 23, 2024 | 07:58 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to X204 forum...
Old Feb 23, 2024 | 08:49 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Maybe a 30 second YouTube video highlighting the ticking would be helpful. One person's ticking might be very different than others think ...
Old Feb 23, 2024 | 09:59 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Many possibilities:
Dry and cracked serpentine belt
Cracked plastic pulley or idler
Loose exhaust manifold
Cracked exhaust manifold
Valve train component
Dry and cracked spark plug insulator
And on and on …
An auto diagnostics stethoscope can help pinpoint the location. Just be careful around the belt, pulleys, and radiator fan.
Old Feb 24, 2024 | 05:28 AM
Silver Shadow's Avatar
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
Mine has ticked since the day I bought it 4 years ago. It hasn't gotten worse in that time. I just assumed it is normal. What, me worry.
Old Feb 27, 2024 | 03:22 AM
titanxie's Avatar
2014 GLK 250
I bought my 2014 GLK 250 Bluetech brand new. And this year comes my 10th year of ownership. There is always a clicking noise from under the hood. I can only notice it when I slowly crews close to a wall on the driver's side with window down, so the clicking noise would bounce back to me. The clicking time interval is about every 3-4 seconds. If what I have descripted is same as what you have experienced, I wouldn't worry about it.
Old Feb 27, 2024 | 06:40 AM
Mmr1's Avatar
2013 glk 350
The high pressure fuel pump clicks, mine does, my 13 always has a bit. There are different “clicks” , valve lifter , timing chain , high pressure fuel pump, main bearing, , I can’t hear it from here. Use a stethoscope to pinpoint it. , just a broom stick will work!
Old Mar 2, 2024 | 02:06 PM
Rascally Wabbit's Avatar
2010 Mercedes GLK 350, 2001 BMW Z3 3.0 Roadster, 1997 Cherokee XJ
Interesting & helpful comments regarding the engine ticking noise. Several possible causes are mentioned, some of which I had not considered. Another one to consider is wear in the counterbalance shaft chain. This applies only to the 2009-2012 models because the engine introduced in 2013 is a 60 degree V design. It does not have the counterbalance shafts.
