Parking brake cable adjustment?
Old Dec 2, 2024 | 08:55 PM
DenisMcG's Avatar
Veteran: Canadian Forces
2015 GLK 250 Bluetec
I just changed my parking brake shoes and associated parts. I have adjusted the shoes properly (adjuster tightened till rotor locks then back off four clicks). Unfortunately the wheels are not fully braked when I push the pedal fully. I can't find any info on a cable adjustment and the parts diagram does not show any adjustment area. Does anyone know if the cable can be adjusted?
Old Dec 3, 2024 | 06:47 AM
Mmr1's Avatar
2013 glk 350
No idea on adjusting cable , you replaced pads because brakes did not work. I would look to see if they move at all! Maybe cable is not hooked up to pedal !
Old Dec 3, 2024 | 07:01 AM
DenisMcG's Avatar
The parking brake engages. If I jack the wheel up, I can't turn it by hand with the parking brake, it is easy to turn when the brake is released. However, if I stop on a hill and place the transmission in neutral, then press the parking brake pedal, the car rolls. I have read that it should take 4-5 clicks of the pedal to fully engage the parking brakes. Mine is almost to the floor before the brakes are engaged. That is why I was wondering if there might be somewhere to adjust the cable..
Old Dec 9, 2024 | 10:04 AM
DenisMcG's Avatar
Update: It turns out there is no ability to adjust the cable tension anywhere on the GLK. The only adjustability is via the adjuster at the shoes. I decided to simply turn the adjuster till the rotor no longer turns then back it off a bit to allow for free movement of the rotor. This is about two clicks on the adjuster. I can feel a little movement of the car when the parking brake is fully depressed but it is minimal.
Old Dec 9, 2024 | 12:02 PM
Mmr1's Avatar
2013 glk 350
Old brakes you back up and brake to adjust . I don’t know about parking disk
Old Dec 9, 2024 | 01:38 PM
DenisMcG's Avatar
The parking is just like old drum brakes except the back up to adjust thing is not applicable on our GLK, You just turn the star wheel to adjust. It is a bit of a pain but doable.
Old Dec 9, 2024 | 03:49 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Deleted
Old Dec 9, 2024 | 08:14 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
You're talking about "modern" self adjusting drum brakes.
Adjusting the star wheel is "old" drum brakes. Then there are those "ancient" ones where you adjust the anchor pins...
According to the WIS, you back the adjuster off 8 teeth. I did mine that way and they work fine. (New disks and old shoes). I wonder if your cables are hanging up somewhere and fouling up your adjustment.
Interestingly, my Volvo was just the opposite. No shoe adjustment and all the adjustment was done with the cable. Sometimes there just wasn't enough adjustment. There was an aftermarket kit to add the star wheel adjuster.
Old Dec 9, 2024 | 08:19 PM
DenisMcG's Avatar
The parking brake on the GLK is exactly like old drum brakes. The drum is part of the rotor. They are adjusted using the star wheel.
Old Dec 9, 2024 | 09:19 PM
John CC's Avatar
I was joking. There are older designs than that.
I remember some drums had a slot cut in the outer face where you could slip a feeler gauge in between the shoe and drum for a more precise adjustment.
Old Dec 9, 2024 | 10:31 PM
Odd Piggy's Avatar
I had those exact brakes on a car. But they are the service brakes. The e-brake (e for emergency) was a band that grabbed the outside of a drum on the transmission output shaft.
4 wheel power disc with 4 channel ABS was still about 4-5 decades away.
Old Dec 10, 2024 | 09:29 AM
John CC's Avatar
Yeah, the picture is from a '46 Jeep CJ2a. I had one back in the 1970's. It also had a drum e-brake, on the output of the transfer case.
It had a star wheel for each shoe.
Old Dec 10, 2024 | 11:51 AM
MBKLUE's Avatar
Yikes:
I've had different cars over the years ( models and brands). I've never had one that did not have a dedicated cable adjustment. Not having one seems weird to me. I wonder why MB chose that route...
Old Dec 10, 2024 | 12:26 PM
Silver Shadow's Avatar
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
A foot pedal parking brake is an old technology as well. Like the foot operated hi/lo beam switch and lower vents with a pull knob.
Old Dec 10, 2024 | 01:34 PM
MBKLUE's Avatar
Yikes:
Originally Posted by Silver Shadow
A foot pedal parking brake is an old technology as well...
In what sense? Do you mean it comparison to a handbrake?
Old Dec 10, 2024 | 02:20 PM
Electronic parkng brake.
Old Dec 10, 2024 | 02:49 PM
MBKLUE's Avatar
Yikes:
The "electronic" parking brake uses either an electric motor or a solenoid, both of which were invented in the early 1800s. Is that not also old technology? Having a strictly mechanical brake that is not dependent on electricity/a battery makes a lot more sense. Finally, a mechanical parking/emergency brake pedal or handbrake, if used correctly, can be used to modulate the braking force applied in the event of hydraulic failure of the braking system.
Old Dec 10, 2024 | 03:15 PM
I had originally written handbrake and electronic brake but wishing to avoid a lecture on what's old or new, I deleted handbrake. My mistake. You just can't win on this forum no matter you post. It's either contradicted, misread or misinterpreted. I should just quit. It's too frustrating.
Old Dec 10, 2024 | 03:29 PM
MBKLUE's Avatar
Yikes:
...You just can't win on this forum no matter you post. It's either contradicted, misread or misinterpreted. I should just quit. It's too frustrating.
I didn't know that being on this forum was about winning. You didn't write that it's frustrating but rather that it is too frustrating. If it's too much maybe put your well-being first.
Old Dec 10, 2024 | 04:23 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Holiday season can be stressful.
Anyway, I find the posts "interesting", because I count on, and much appreciate , the information provided by folks out here. To me, folks out here are very involved and not disagreeable. Your posts are fine - ignore the folks who need attention 👍
Yea, there's the rare and occasional troll, to be expected - they are short lived. Before "forums" were popular, I was heavily involved with USENET (I began in early 80's with dial up modem) ... talk about needing a skin of stainless steel
Anyway, back to business, as they say
Old Dec 10, 2024 | 06:05 PM
DenisMcG's Avatar
Strangely, Mercedes does have cable adjusters on most of their vehicles, just not the GLK, and I am sure a few others.
Old Dec 10, 2024 | 08:49 PM
John CC's Avatar
Some people got no sense of humor!
Old Dec 10, 2024 | 11:48 PM
Odd Piggy's Avatar
Don’t quit! I feel like some of you are my friends even though we’ve never met! And sharing experiences with these occasionally unusual vehicles helps all of us.
This site is a lot more gentle than another MB general help site. It’s hard to convey sarcasm or gentle ribbing without facial expressions. The real trolls make themselves clearly known (and unliked).
Old Dec 11, 2024 | 12:55 AM
MBKLUE's Avatar
Yikes:
Cost savings? It seems to make sense to have one adjustment to compensate for cable stretch and then individual adjustments (Brake shoes) for each side.
Old Dec 11, 2024 | 07:43 PM
Odd Piggy's Avatar
I’m still a bit surprised that there’s no turnbuckle in the cables somewhere to take up slack and make a coarse adjustment.
