GLK Wheel Specs.
Old Oct 3, 2009 | 12:53 PM
WpgGLK's Avatar
2010 GLK
GLK Wheel Specs.
Is there a sticky or thread showing the specs on the wheels that will fit the GLK?
Wheel & Standard Tire Size:
17" x 7.5": 235/60-17
18" x 8.5": 235/55-18
19" x 8.5": 235/50-19
20" x 8.5": 235/45-20
ET: From what I can determine, it's 47.5mm. Is this the OEM ET for all size wheels?
Presume that higher ET's will fit with appropriate spacers.
And, less ET will poke slightly depending on difference. (2.5mm = 10th of an inch and so on).
Hub: 66.6mm
Lug pattern: 5 x 112mm.
Sorry if it's a newbie question but I want to build my own winter wheel / tire set up and I need to be able to ask the right questions.
I have filled in what I believe to be correct?
Cheers.
Old Oct 3, 2009 | 02:59 PM
Baby G's Avatar
GLK 350
Yes ur sizes are correct, in my research I have done. Best of luck and let us know what you find.
Old Oct 25, 2009 | 02:25 PM
jftjim's Avatar
GLK was my neighbors-- I drive a 3.0 CRD in Jeep's clothing
GLK wheels/tires
I hope you cam up with wheel and tires --the OE are like $2,500 for just tires. Please let me know what you found as a good wheel replacement
Thanks --Jim in Colorado and it as snowing as I type.
Old Oct 25, 2009 | 08:50 PM
camper88's Avatar
GLK 350
Originally Posted by jftjim
I
Well for goodness sake, man!
Stop typing!
Old Oct 26, 2009 | 12:51 PM
jftjim's Avatar
solved wheel and tire
TireRack.com
Austin 888-428-8355 x 746
Has about a dozen 17" wheels to fit and then can mount Blizzacks
$976.81 at your door. New sensors are $220.00 --more
Tell him Jim Thompson sent you
Old Oct 27, 2009 | 09:39 PM
NYCGLK's Avatar
GLK 350 / Porsche 993
I believe stock 19's are 19x7.5 not 19x8.5, I def. remember there is an inch difference in width between 19 and 20. Offsets for 19 and 20 are different, because of different width of the rim.
Also ppl have put 22x?? with 265 tires.
Here are all GLK stock rims with specs
http://www.service-shop.mercedes-ben...8ebMBGBMe_Hw==
Old Jan 1, 2013 | 03:35 AM
popp's Avatar
'09 C350 4M, '11 Sienna SE, '84 VW Jetta GLi
has anyone physically put a 235/55r18 on a 2012 GLK? Because my local tire shop says 19" is the smallest.....
Old Jan 1, 2013 | 04:29 AM
jftjim's Avatar
wheels 17 inch
My neighbor has the wheel and nuts and covers sitting in her garage in Evergreen Colorado. She sold the car but I told her to put the orginal wheels on before she sold it. Just give a reasonable offer and they are yours. 303-594-1672 Jim-- I know they fit- she had blizzaks on and it was a huge difference.
Old Jan 1, 2013 | 10:15 AM
dcjwlee's Avatar
2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
17" is the smallest.
Old Jan 1, 2013 | 10:37 AM
jftjim's Avatar
The smallest that came up as a replacemnt for the GLK. The 17" fit for sure with still good room for calipers and rotors. Allowed a greater choice of tyres with a less out of pocket expensive and probably a better ride due to the greater volume of tyre. which is needed to keep the correct dia.
Old Jan 1, 2013 | 10:52 AM
Mort's Avatar
I am running 17x 8 with 235/65/17 Michelin Alpin HP winters I bought for our R-Class and they are working fine.
Old Jan 10, 2013 | 01:26 PM
packardbell's Avatar
civic corrado glk
running 19X8.5 shod with pirelli 235/55/19 ice and snow
Old Feb 10, 2014 | 05:22 PM
mykim72's Avatar
W204
subscribed...
Old Aug 17, 2014 | 02:33 PM
Nitrocarbon's Avatar
GLK350
255/40/20 on stock GLK 20" Rims
I want to put 255/40/20 on my stock 20's. Has anyone done this?
Diameter is basically the same and they end up being .75 inches wider.
My only concern is the rim only being 8.5 inches wide. - Thoughts?
Old Aug 18, 2014 | 12:09 PM
Mr. JLT's Avatar
To many to list
i run a 255/35/20 on a 9.5/10 rims on my GLK
Old Mar 5, 2015 | 06:41 PM
Gsr4logan's Avatar
2011 glk350
Wheels specs
Hi i love ur set up. What is the offset on your wheels? Thanks
Old Mar 6, 2015 | 03:30 PM
Toppthat's Avatar
2014 glk250
Really nice. I'm torn between a new rim from mercedes( if cheaper then 1350) or 5 totally different ready to go from tire rack 19 or 20s?
Old Mar 10, 2019 | 05:31 PM
bemel2's Avatar
2006 C280
No problem with the 255 40 20 setup. I have 265 40 20 Pirelli P-Zero on my rear & no rubbing problems at all. Won't even notice the difference in ride height.
Old Mar 11, 2019 | 06:02 PM
tawatts's Avatar
2013 GLK350 4Matic; 2010 Audi A4 Quattro; 2004 Yamaha R1
Brabus show a staggered setup for the x204, running 255/40/20 on 8.5"x20" ET35 & 285/35/20 9.5"x20" ET45 height difference from front to rear with this setup is .1" rolling diameter or 0.4%
Has anyone tried the Brabus staggered setup? I'm thinking of going for this and adding the H&R lowering springs with the Bilstein B6 struts all at the same time.
Brabus wheels and offset for x204.
Old Jan 25, 2023 | 04:26 AM
Boercker's Avatar
2010 GLK350, Turbo Cobra, Coyote F150, SV650 Golf Cart, Foxbody 5.0
Attachment 376064
Attachment 376065
Attachment 376066
old thread here but what offset were you running on these (or are you if you still have it lol)
