GLS Class (X166) Produced from 2016 to 2019
2019 GLS450 music from USB
Old Sep 6, 2021 | 01:20 PM
Sunbeltgolfer11's Avatar
E63s SL550 GL450
We just bought a lightly used GLS450 to add to our fleet. It has the HK Logic 7 stereo system and for some reason we are not able to play music from a USB drive. The drive works in our 2014 SL550, 2016 GL450, and 2021 E63s.There are two ports in the center console and we've tried them both with no success. Is there something different in the 2019 GLS system that I'm missing?
Old Sep 8, 2021 | 04:03 PM
4everalone's Avatar
2008 Evo X GSR & 2014 GL550 & 2012 A6 3.0T
I would check to see if the ports are even functional. You can try connecting a phone to each and see if either is delivering power.
It could be a simple fuse issue like this following thread implies:
https://mbworld.org/forums/gl-class-...t-working.html
Old Sep 8, 2021 | 07:52 PM
E63s SL550 GL450
Thanks for the response When the drive is plugged in the system recognizes you're trying to connect someting, but doesn't play the music. For some reason it doesn't seem to be able to read the data. The same thumb drive works in our three other MB's without issue. I guess I need to take in and have it checked. In the meantime I've downloaded a bunch of CD's so I have something to listen to.
Old Sep 11, 2021 | 04:14 PM
chassis's Avatar
2017 GLE350 4MATIC
Use the bottom port and select "Media" using the button on the center stack or in COMAND. When you do this, what happens?
I use my iphone all the time as an "ipod" using a USB cable and it works without a hitch.
Old Sep 12, 2021 | 10:50 PM
E63s SL550 GL450
I'll try that the next time I drive it. Seems like we may have gotten an unable to read message from the lower port, but I'm not sure.
Old Sep 13, 2021 | 02:09 PM
E63s SL550 GL450
Tried it today. Says "no device connected". I'm going to search online and see if there is any info.
Old Sep 13, 2021 | 05:04 PM
chassis's Avatar
2017 GLE350 4MATIC
Do you have the hardcopy owner's manual? 2017 GLE manual is attached. It should be the same for all post-facelift *166 COMAND vehicles.
From page 144 of the COMAND manual:
File Type: pdf
Old Sep 13, 2021 | 05:07 PM
E63s SL550 GL450
No, I don't. Thanks for the attachment. I'll look through that and see if I can figure it out.
Old Sep 13, 2021 | 05:30 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Originally Posted by Sunbeltgolfer11
No, I don't.
https://www.mbusa.com/content/dam/mb...019_GLS_OM.pdf
Old Sep 13, 2021 | 08:22 PM
E63s SL550 GL450
Thank you.
Old Sep 14, 2021 | 05:29 PM
E63s SL550 GL450
It would appear there is a problem with the USB port. None of the suggestions or following the manual insructions gets music to play. Keep getting the "no device connected" message on the screen. I will get it in for someone to look at it and see if it can be figured out.
Old Sep 14, 2021 | 08:45 PM
chassis's Avatar
2017 GLE350 4MATIC
Have you tried multiple USB cables? They can be flaky. And what about the female cable port on your iphone? It is filled with pocket fuzz? I have experienced these things in the past - bad cable and pocket fuzzed cable port.
Old Sep 15, 2021 | 09:12 AM
E63s SL550 GL450
I haven't used cables. Just plugging a flash drive into the port. When we have used my wife's android phone to play music, it is through Bluetooth and the system recognizes it and plays off that without problem. I don't carry a smart phone so the flash drive is what I use for music. In our three other MB's and it works without issue. The usb ports appear to be clean, but I will give them a shine just in case.
Old Sep 20, 2021 | 08:48 PM
Boraxo's Avatar
GLS450
concur. It is either the port or sometimes a defective cable. Try the other port (ours has a couple I think). Try an ipohone or a different device. Flash drives can be flaky as well with the port.
Old Sep 21, 2021 | 02:19 PM
E63s SL550 GL450
Both ports fail to recognize a flash drive when installed following directions from the manual. Will take it in to have it looked at and see if they can figure it out.
Old Sep 21, 2021 | 07:24 PM
chassis's Avatar
2017 GLE350 4MATIC
@Sunbeltgolfer11 Have you tried with a smart phone? I know you said you don't have one. What about a friend, spouse, etc.? Do you think your flash drives could be the problem?
Old Sep 21, 2021 | 07:27 PM
E63s SL550 GL450
Yes, my wife has an android and it plays fine via Bluetooth. The only thing that doesn't work are my usb drives that all "my" music is loaded on. Thought about getting a smart phone, then quickly thought better of it. Just can't get into the 20th Century, let alone the 21st.
Old Sep 21, 2021 | 08:57 PM
chassis's Avatar
2017 GLE350 4MATIC
@Sunbeltgolfer11 Have you tried your wife's Android via the USB cable? You need to try someone's smartphone with a cable plugged into the USB ports in the center console storage bin. Not via bluetooth.
It's quite likely your 1980s USB sticks are the problem.
Old Sep 21, 2021 | 09:26 PM
E63s SL550 GL450
No, I haven't done that. Just seems strange that the usb works in our three other MB's. I will take the cable out of my E63 and see if it works with that.
Old Sep 23, 2021 | 09:01 AM
E63s SL550 GL450
Connected the wife's phone to the usb port with a cable yesterday. Same results. Screen says device not connected. Tried both ports and got the same message.
