Winter Tire options for GLS 23” wheels
My question for this forum is whether I can mount the below GLE 22” wheels (starred) on a GLS 580 (x167 / MY2021). To further complicate it, these stock GLE rims are staggered and I can only find winter/all-seasons for the front rim size since the rears are to wide. So I want to buy two pairs of front GLE rims and use them as my winter rims on my GLS. The circumference is not an issue but I’m not sure about the (1) wheel offsets or (2) lug pattern / size, and (3) caliper clearance and whether it will work on the GLS580.
WHEELS:
- GLS 23" AMG Twin 5-Spoke Wheels w/ Black AccentsR01, 690
- 285/40 R23 on 9.5 J x 23 ET 45 (Front) (Circumference 100.46)
- 325/35 R23 on 11.5 J x 23 ET 47 (Rear) (circumference 100.39)
- WINTER TIRES (none available)
- ***GLE 22” (same style as above GLS 23”) AMG Twin 5-Spoke Wheels w/ Black Accents
- 285/40 R 22 on 10J22 ET56.1 (Circumference 97.32)
- 325/35 R 22 on 11J22 ET50 (Circumference97.25)
- IF - 285x45R22 (Circumference 100.84”) Bridgestone Blizzak DM-V2 https://www.bridgestonetire.com/tire...-v2/p285-45r22
OTHER WHEEL OPTIONS
- GLS 21” AMG Twin 5-Spoke Wheels
- 275/45 R21 on 10J x 21 ET 44 (Front)
- 315/40 R21 on 11J x 21 ET 42 (Rear)
- *GLE 20” (same style as above GLS 21”) AMG 5-Spoke Wheels w/ Black Accents
- 275/50 R20 on 9 J x 20 ET 57
- 275/50 R20 on 9 J x 20 ET 44
- GLS 22” AMG Multi-Spoke Wheels
- 285/45 R22 on 9.5 J x 22 ET 45 (Front)
- 325/40 R22 on 11.5 J x 22 ET 47 (Rear)
- GLS 20” Twin 5-Spoke Wheels
- 275/50 R20 on 8.5 J x 20 ET 62.5 (Front)
- 275/50 R20 on 8.5 J x 20 ET 62.5 (Rear)
https://mbworld.org/forums/gls-class...er-set-up.html
https://mbworld.org/forums/gls-class...ml#post8181159
https://mbworld.org/forums/gls-class...ml#post8276370
https://mbworld.org/forums/gls-class...ml#post8285110
There a several Pirelli Scorpion winter in correct 21 inch sizes with MO designation for the staggered 21 inch factory wheels. Here is a link to the the MBUSA site where you can buy them. Don't use the GLE rims they have the wrong offset. Buy the GLS 21 inch staggered set with the correct offset and put on these tires, it is the simple solution.
https://www.mbusatirecenter.com/app/...21,315%2F40R21Last edited by marchgroupinc; Jun 21, 2020 at 09:10 AM. Reason: new additional info.
I discovered that Pirelli makes the scorpion winter tires in sizes that will fit the staggered GLE 22” rims yet still be large enough to work with the GLS (i.e.,285/45R22 & 325/40xR22). So if I want to have a set of 22” winter wheels that are the same style as the stock 23” wheels then I just need to confirm that the above 22” wheels from GLE580 can fit on the GLS580 which seems likely even if the offset is different.
I randomly stumbled on this GLS580 that seems to have the 22” version of the GLS580 23” OEM wheels. I’m guessing these are the stock wheels of the GLE580 that the dealership or purchaser had installed on this GLS. I’m guessing this was done to accommodate cold weather tires.
At first glance I assumed these 22” wheels are the optional stock ones from a GLE580. But I’m pretty sure the 22” rims from GLE580 have much thicker black rim sidewalls and aren’t nearly as low profile as the equivalent portion on the 23” rims of the GLS580 even though they are the same style.
1) purchase an extra set of front GLS 23” wheels and put them on the back since they have all-season tire options for that width.
2) purchase a set of the staggered GLE 580 22” wheels that look very similar the GLS580 23” wheels and put on winter tires and use them as my winter tires each season.
PS: I updated the original thread to add cross references to other threads on this forum that relate to winter tires for the GLS (some relate to the 23” wheels).
20" all seasons
23"
No need to spend the money on OE wheels for Winter, the salt/sand/cinder/etc will take its toll on them so just go for a solid quality aftermarket wheel with the best Winter tire you can get. The setup above fits perfectly, kept the proper stance look of a staggered set and no problems with the speedo since it is the same OE tire sizes.
You can go for a 22" setup as well but the only rear tire offered for Winter is the Pirelli Scorpion and I personally am simply not a fan of that tire as it does not do as well as other tires on the market.
I’m trading in my GLS so happy to sell if interested. They have only been used for one winter season in Canada
