Killed RX8
). Now the RX-8, THAT is a torqueless JUNKER.
What was Mazda thinking? Answer: They weren't!
-Matt
Mazda, you listening out there?
).It's a shame. They could release an RX-7 on steroids (nice fat 325s in the back
) with 500 - 600Hp either in N/A form (all Aluminum quad rotor Renesis) or a single turbo Aluminum Triple rotor in a 2,800 car (make the whole body Aluminum...RX-7 are small so no big raw matl costs). Sell it for $100k & improve the workmanship/materials to today's standards. (&*uck I'd buy it!
OK, ....wake up Matt....WAKE UP!~)
See ya,
-Matt
See ya,
-Matt
I wish/hope you are right but I'm not "doubling down" any time soon on Mazda. The other Japanese firms have "evolved" (ie created brand recognition & market penetration via their Infiniti & Lexus lines). WTF has Mazda done? Minimal progress, at best. The other makers have evolved into making Pyramids. Mazda guys are just now learning how to make fire.
I like the old RX-7s too but that car company is now royally f-ed via Ford's controlling interest. Too bad...time to move on....many other cars/choices out there.
-Matt
I love the sound from the V8 model- it really does burble.
When I was a service writer/assistant manager with a Ford, Mazda and Buick dealership many years ago.....we would have 45k-60k mile RX-7 twin turbos coming in with stalling problems and lack of power. We knew right away it was the apex seals failing. Mazda did not allow us to rebuild the engine so they would replace the engine instead. If you were out of warranty....you were out of luck. The engine was @ $18,000 without turbos and a/c so we would send customers to a rotary specialist in Fort Worth. Man, the look on the customer's face when we told them they needed a engine!
The older owners of that car were almost as bad as the miata owners with their sh*t-don't-stink-attitude .
The younger guys were always cool....they didn't want to **** us off because we still did warranty work to their modded cars.
Apex seals don't begin to fail causing the problems you listed. Apex seals fail entirely (break) when detonation occurs (detonation is ~ 12,400 lbs/Sq inch of force - that will break just about anything). Dotonation occurs when there is inadequate fuel (cuased sometimes by bad hoses or improper engine modding which leans the A/F out). A broken seal will rotate within the rotary housing damaging the housing and/or the turbos when its exhausted out of the housing (blown motor - unmistakable ROUGH idle).
The problem you list can be caused by several factors: A) a general lack of compression due to tired seal springs which generally starts occuring after ~ 10 yrs or 100k miles, B) turbo hoses that have dry rotted - almost ALWAYS the cause for the problem you listed. The simple remedy is not an engine replacement but a silicone hose replacement for the OEMs.....they dry rot after ~ 3 yrs due to the high heat the twin turbo rotary produces - silicone replacement hoses never fail.
Mazda did a horrible job in:
1) not using silicone for the 80 hoses used in the sequential turbo system
(an easy fix, ~$350 installed & they last foreever)
2) Not training their Dealer mechanics on proper rotary diagnoses (and not
offering the above hose upgrade/fix as part of a broad based Recall)
$18k for an engine replacement? Not only was it not neccessary but a complete rip-off. My brother & I have pulled, ported, & installed rotaries for $7k (2007, not 1995 dollars
) for over 20 yrs as a hobby. I never let Dealers touch my car. They were & remain CLUELESS about rotaries (maybe they are better on the newer Renesis powerplant but they don't know Jack about FD powerplants).See ya,
-Matt
read here.............
http://www.rotarydynamics.ca/QA.html#Q1
True, heat can be a cause of apex seal failure. Oddly enough, so would a lack of driving and extended storage time; both causing carbon build up in an engine already known for it's "hot" and "cold" spot dirty combustion. (Rotaries are notorious for poor fuel economy and poor emissions) Hence low mileage RX-7 twin turbos coming in that have been babied my mid-life crisis men seemed to have had the most engine problems.........as I stated above.
TSB's by Mazda argue with you greatly Yellow R1.
