Kill Stories Discuss your exciting high speed excursions here!
Spanked By An S4 Today
Old Apr 28, 2013 | 12:20 PM
speedpeddler's Avatar
2014 E63, Cobra replica, 68 Camaro, 66 Chevy II SS, Z4 BMW, Honda Element, Birel 125cc Shifter Kart.
Only played with one previously and never really had a race but appeared my E was a bit quicker. Had a guy in an S4 want to go on my way back from the beach this morning so I went and got spanked. That was completely unexpected.
Started at around 60 and he got a good jump on me but I thought I was reeling him in until we ran out of room and had to call it off.
Don't believe a stock S4 can do that. Thoughts?
Old Apr 28, 2013 | 06:38 PM
LS417's Avatar
11' S4 (Tuned)
Assuming you're talking about the 06 E55 in your list.. the S4 was likely tuned.. stage 1 / 2 S4's are quite potent (2010+).
Mine ran a 12.44 @ 111 with just software, the most conservative one at that(stasis). Some Stage 2 cars run 11.7-11.9 @ 118-119.
Last edited by LS417; Apr 28, 2013 at 06:40 PM. Reason: edit: yay 1st post.. I'm usually just a lurker
Old Apr 29, 2013 | 08:53 AM
Yep. Definetly the E55 which is factory stock. The S4 had a nice exhaust sound that was not stock and also a nice set of non factory wheels and tires so I doubt he was stock. Still, he pulled me pretty hard considering even a stock E55 is pretty quick.
No way he beats me in either my Camaro and certainly not in my Factory Five Cobra both of which are quicker than the E with the Cobra, (2,100 lbs and 475 HP), being quite a bit quicker. Have never lost in the Cobra and only to a Z06 in the Camaro but, it was close.
Old Apr 29, 2013 | 09:12 AM
LS417's Avatar
11' S4 (Tuned)
Cobra sounds like a beast!
Old May 4, 2013 | 04:43 AM
Deuuuce's Avatar
Charger SRT-8
Is your IC pump working?
Old May 6, 2013 | 03:18 PM
Working well. Got the new Bosche pump. My car runs as well as it ever has, just not strong enough for that particular S4.
Old Aug 9, 2013 | 10:10 PM
Deuuuce's Avatar
Charger SRT-8
I should ask, what year/generation S4??
Old Aug 17, 2013 | 11:52 AM
For the record, I don't know **** about Audi cars. This one looked to be an older model but was obviously modified. I could see and hear his aftermarket exhaust and he was sporting some nice wide wheels and tires too. Plus, he picked on me first while I was cruising minding my own business. Most guys won't do that unless they think they've got you and I'm pretty sure he's spanked an E55 before by the way he stuck his arm out the window to wave bye bye as he was pulling away.
I was sort of expecting to lose but I like to play a little when the opportunity presents and don't get bent out of shape when I do. There's always somebody faster.
Just for laughs, I've been cruising that same area in my Factory 5 to get even but haven't run into him.....yet.
Old Aug 20, 2013 | 08:34 PM
Deuuuce's Avatar
Charger SRT-8
I belive the B5 generation with K40s is a popular set-up. 500-600rwhp depending upon boost and gas used iirc.
Old Aug 20, 2013 | 10:20 PM
mb techman's Avatar
CLA45
Old Aug 29, 2013 | 02:43 PM
davis449's Avatar
2016 BMW Z4 sDrive35i M Sport
I'll chime in here. Yes, the B5 S4 (2000-2002 MY pictured first in the above post) with OEM Borg Warner K04 Turbo's (from the European B5 RS4 that we never got here in the states) are a popular thing to do. However, modifying one to that level is ~$7K-$10K+ and owning one can be quite costly. Hell, owning just regular B5 S4 un-modded is expensive. The reason there are so many in existence is because the OEM Borg Warner K03's that came on the US spec B5 S4 are highly prone to blowing up, so when they do, many people just opt for the K04's to replace them when they have to go to the expense of replacing the blown K03's. These kits are around 447 HP and 467 ft./lbs. torque at the crank. The next step up from that is to go twin GT28 turbo's and those are the 600+ HP ones running around. That kit is somewhere ~$20K if I'm not mistaken and the engine MUST be built at that point. They are UNGODLY fast.
The B6 (2004-2005.5) that is pictured second in the above post is the same spec as the B7 (2005.5-2008). Those were weaksauce 340 HP 4.2L V8's in a heavy pig of a car. They're slow.
The B8 S4 (2010-Present) with the supercharged 3.0L V6 Stage I tuned are ~360 AWHP and ~345 AWTQ. If they've got the pulley and Stage II tune it's ~390 AWHP and ~380 AWTQ. Not bad numbers and they are ****ing fast, especially when equipped with the DSG trans.
If you got killed by a B6\B7 S4, I would be thoroughly shocked. A B8, even stock, not so much. They're pretty fast out of the box.
Old Aug 30, 2013 | 09:49 AM
Deuuuce's Avatar
Charger SRT-8
Good summary but a stock B8 isn't going to spank an E55 ever. Unless OP actually was reeling him in.
Although it had exhaust, that may suggest a tune as well if it was a B8.
Old Aug 30, 2013 | 10:32 AM
davis449's Avatar
No, you're right, a stocker B8 S4 shouldn't beat an '06 E55.
Old Sep 17, 2013 | 02:48 PM
It wasn't even close. He pulled me immediately from about 40 and kept it up till I backed off because of the wave. I thought he was waving off the race because of traffic or cops I couldn't see so I lifted. Wouldn't have made a diff as I wasn't catching him anyway.
Wasn't nearly as nice as the blue one pictured above but looked similiar.
Old Sep 18, 2013 | 12:27 PM
davis449's Avatar
Which blue one? The pictured cars above are both blue and different models.
Old Sep 18, 2013 | 02:39 PM
Need4Speed's Avatar
Former Vendor of MBWorld
2018 C63S
That Audi
was tuned
100%
i work on Audis and on MB alot
and to be truthful i have buddies with these cars that have done runs head to head
and the stock E55 spanks the Audi
so that car is tuned for sure
Old Sep 19, 2013 | 09:50 AM
davis449's Avatar
Originally Posted by Need4Speed
That Audi
was tuned
100%
I asked the question above because a tuned B6 or B7 S4 wouldn't spank an E55.
Old Sep 19, 2013 | 05:36 PM
Need4Speed's Avatar
2018 C63S
it depends to be honest,but you are correct in 99% of cases
BUT
There is one yellow B7 S4 here where i am located
tuned and upgraded by a local tuner
and that car is so ridiculously fast i cant even explain to you how fast
it takes on fully built EVO 9s pushing well over 450 WHP
and has eaten a E55 alive
i know sounds impossible
but nothing is impossible
Old Sep 20, 2013 | 09:25 AM
davis449's Avatar
BUT
No less than forced induction would make that possible.
