ML 430 dies at idle wont start for 20 min
Old May 1, 2007 | 11:59 AM
dgrideout's Avatar
83 380 SL, 99 ML 430
I have a 99 ML 430 that has begun dying during a lifted throttle when warm. It will not start again for about 20 minutes. There is no indication that it has a problem. It is running fine and then just dies. So far it has never died while under a load. It always quits after you come to a stop and are idleing.
Any Ideas?
Thanks, Dave
Old May 1, 2007 | 05:10 PM
///AMG55's Avatar
XLR
How many miles do you have? Is your check engine light on? Have the codes run. Its probably your MAF - mass air flow sensor.
Old May 2, 2007 | 07:41 AM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
Any Ideas?
Thanks, Dave
Could be a failing CPS (crank position sensor). If you haven't changed the original one yet, thats probably the problem. Its a common problem that leaves no codes. My 2 cents.
Old May 2, 2007 | 03:39 PM
benzeboy's Avatar
ml320 & c240
Agree with azinn. It happened to me and I went ahead and change my cps. and that fixed the problem. It's the cheapest way to go and if that is not the problem you still eleminate that from happening in the future. Good Luck.
Old May 3, 2007 | 09:38 AM
dgrideout's Avatar
It has just over 100.000 miles. It has no codes this time. It did have a MAF code previously and I replaced the MAF and cleared the code. But the problem still exists. I will order and replace the crank sensor next. As you say, it needs to be replaced at this time anyway. Thanks for your help.
Dave
Old May 22, 2007 | 07:50 PM
Wolfwinter's Avatar
CPS
Old Jun 4, 2007 | 11:06 PM
detabo's Avatar
ML 430 1999,came todat to my workshop with the same problem.Crank position sensor replaced,and problem solved.If you have Esitronic check out the Robert Bosch notes about ML430 and you will see service info about problem like yours.
Old Aug 29, 2007 | 08:33 AM
My ML's Avatar
l sl 7.3 koenig l cl 7.3 koenig l Ml 350
that is crank shaft sensor thats what happend with mine
