flashing ecu
Old Jan 12, 2008 | 12:56 PM
auto art's Avatar
flashing ecu
has anyone here had their ecu reflashed,or installed a chip by powerchip or anyone else?I woul like to hear from you.and you thoughts.
Old Jan 14, 2008 | 01:14 PM
Porschenut's Avatar
2000 ML55 AMG Black on Black
I have the 93 octane program and I can feel a difference. It's not night and day, but definitely an improvement. Everything is pretty straightforward with this modification. The only snag that I hit was when I re-installed my ECU after getting it back. For some reason I had to install it twice since the first time I re-installed it, there must have been a loose plug and the truck wouldn't start up. I took the ECU out and re-installed it a second time and it started right up.
It's pretty intuitive the way the plugs insert and lock in to the ECU, but pay careful attention and memorize how everything comes apart. It may also take you an extra few seconds to figure out how the slide lock works on some of the larger harness plugs, but once you do, you could re/re the ECU in a few minutes.
One last note, overall I'm not sure that it's really worth the money. $1000 is a lot of dollars for <10% more power and more expensive gas. If it was only $400 it'd be a no-brainer.
Old Jan 14, 2008 | 04:41 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i'll be going with SI ECU tune once my car is all fixed from body shop...
price is $600 which is pretty good considering 16hp 17lb-ft gains...
Old Jan 21, 2008 | 04:16 PM
auto art's Avatar
I have not heard of "si" is there a web site for them?I saw that you have 2 cars, are you getting it for the ml?let us know how it goes.
Old Jan 21, 2008 | 04:26 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
www.SpeedInnovation.com
i'll get my ML tuned as soon as i get my car back from the body shop...
Old Jan 23, 2008 | 01:35 PM
auto art's Avatar
I called "SI"and talked to Jessie,he told me it would add 18hp/24tq and cost 799.00.Then i called Powerchip and talked to Ben, he told me it would add 20hp/22tq and cost 490.00.Both on the ML 350.
Old Jan 23, 2008 | 01:44 PM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Not to criticize any other tuners but our testing involves track and on the dyno before we actually have a dialed in software for each engine; including the 350.
Evotech software for the 350 engine is $995.
Adam
Old Jan 23, 2008 | 01:55 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i got quote for 599 from k1 for si tune...
Old Jan 23, 2008 | 06:57 PM
auto art's Avatar
Adam, what kind of gains do you have for the ml 350?
Old Jan 23, 2008 | 09:59 PM
Depending on the level of octane you are using. About 20/25 on average performance gain we seen with our clients.
Adam
Old Jan 28, 2008 | 11:49 PM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
Renntech
I had this misfortune of trying the RENNTECH DOWNGRADE for the ECU and TCU - a total disappointment.
Lack of Performance followed by a long list of excuses.
