Check engine light/spark plugs???
When driving the car, the engine performance feels fine so I was curious why the light came on. Certainly isn't misfiring or stalling or running weak....Could any damage occur if I don't replace the plugs? Thanks.
Dealer replaced my plugs along with the MAF under warranty on my '00 ML430 last week at 46,000 miles. SA said plugs need to be replaced when MAF is bad, I guess they get dirty. Truck seemed to run okay to me.
The CEL keeps coming on on my wife's 1998 ML320. What exactly is the MAF? One time, the gas cap was ont tight, and the SEL light came on. NOw, something periodically causes the ML to go into "limp home mode" even when the SEL is not on. does anyone have a clue what might cause the CEL to come on, or what might cause the ML to go into limp home mode (with CEL out)? thanks
A: Mass Airflow sensors contain a thin-film, thermally isolated bridge structure containing heater and temperature sensing elements. The bridge structure provides a sensitive and fast response to the flow of air or other gas over the chip
I experienced similar problems (shaking truck, limp home mode, etc.) on my 98 ML320. I tried the cheap stuff first (Fuel additive, spark plug replacement) since my ML was no longer under warranty. Changing the spark plugs were a definite pain in the rear! I ended up damaging one spark plug wire in the process (set me back $70). Anyway, I bought an ODB-II Code Reader and managed to isolate the problem to a bad MAF sensor. It was a simple fix that you can do it yourself. In fact, I did it at the dealers lot. I paid $293 for a new one from the dealer.
• 12/12/02, 60480 miles.
Replaced Mass Air Flow Sensor.
p/n: 112-094-00-48
• 11/30/02, 59979 miles
Replaced spark plugs w/ Bosch Platinum +4.
sorry for your troubles...i think its just the MLs are terrible
thanks
[SIZE=3][SIZE=3]
