W163 ABS Pump Module
Old 08-02-2017, 12:40 PM
MDSTRAVEL's Avatar
clk320/ml270
mercedes w163 ml270cdi, Abs pump module is faulty have acquired another module but the electrical multi plug will not fit, the multi plug on my vehicle is colour Blue the multi plug that came attached to the replacement unit is coloured black what is the difference in these plugs please
vin WDC1631132x739298
Old 08-02-2017, 02:49 PM
Plutoe's Avatar
Received 1,022 Likes on 950 Posts
1999 E300TD
To learn the correct replacement----post your VIN
PS: you wasted your money by not checking for the correct part first!!
MDSTRAVEL (08-03-2017)
Old 08-03-2017, 07:19 AM
MDSTRAVEL's Avatar
clk320/ml270
Thanks for that vin is WDC1631132x739298,
I took the replacement of a scrap model we have at work so not cost me anything yet.
Old 08-03-2017, 07:52 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
How was it determined that the module was faulty?
What were the code/s numbers?
Explain the problem you are having.
Old 08-03-2017, 09:11 AM
MDSTRAVEL's Avatar
clk320/ml270
C1025 seems to be the main code
The problem is Normal brake pedal travel but poor braking effect on the rolling road it has enough pressure to register enough to pass the MOT test, the rollers only equivalent to 4mph, out on the road doing 30mph and it is struggling to stop, according to Mercedes I should be gettin 500 lb/ft pressure on front brakes only getting 250, and on rear brakes it should be 250 lb/ft only getting 125 , so each wheel is only getting 1/2 what it should get.
I have changed the servo,master cylinder,all flexi hoses even fitted new rotors and pads all round no different.
Old 08-03-2017, 09:20 AM
Plutoe's Avatar
1999 E300TD
[QUOTE=MDSTRAVEL;7228583]Thanks for that vin is WDC1631132x739298,
QUOTE]
I think we have a description issue as the VIN does not show the vehicle has an ABS system---do you have a part number or what does the module control?
Old 08-03-2017, 12:51 PM
MDSTRAVEL's Avatar
clk320/ml270
Part number
[QUOTE=Plutoe;7228676]
QUOTE]
Part number is A1634310512 10.0210-9686.1 this is the number of the original, the replacement is A1634310512 10.0947-1501.4
Old 08-03-2017, 12:54 PM
You say the main code is C1025, but what are the others?
Old 08-03-2017, 12:58 PM
MDSTRAVEL's Avatar
clk320/ml270
codes
the others are non brake related P1481,P1664, P1354.
Old 08-03-2017, 01:19 PM
Here is the ESP Control Module part # according to your vin#. The part number you supplied is no longer in the M/B system.
Old 08-03-2017, 02:55 PM
MDSTRAVEL's Avatar
clk320/ml270
Thank you for that
Thanks for the info will have another go at things this weekend.
Old 08-04-2017, 12:12 AM
Yes the module could be bad, but you are not considering the fact that the codes are stored in that module and when you remove it, the codes remain therein.
Switching it to another veh. will not clear those codes unless they are read and removed with a scanner.
Old 08-06-2017, 05:38 PM
Russell Ormerod's Avatar
not a merc
You barking up the wrong tree! Ineffective brakes cannot be an electronic issue. Are you sure the brake booster is functioning? Is there sufficient vacuum supply? Basics first
Quick Reply: W163 ABS Pump Module
