Dead instrument panel in 2002 ML320
Old Mar 5, 2018 | 04:39 PM
Bill Lewis's Avatar
2002 ml320
Also no instrument panel lights, no indicator or warning lights, and no HVAC controls. Fuses? BTW, the truck starts and runs fine.
Old Mar 6, 2018 | 12:38 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
With the key on, check fuse #5 in the right side kick panel fuse box with a DVOM or test light.
Old Mar 6, 2018 | 10:14 AM
Bill Lewis's Avatar
2002 ml320
Thanks, Neighbor (we're in the Bronx, specifically Riverdale). Should I also check fuse #1?
Old Mar 6, 2018 | 10:36 AM
Please UPDATE YOUR PROFILE IN user CP to include the year and where you live.
Old Mar 6, 2018 | 10:41 AM
You haven't said anything about checking fuse #5 which controls both the I.C. and the A/C Controls. Check all the fuses you want.
Old Mar 7, 2018 | 03:20 PM
Bill Lewis's Avatar
2002 ml320
I replaced fuse #5. That fixed all the problems, I think. I turned the truck off and restarted it, and everything was dead again. Hmm...
So, what's Plan B -- the next step? Ant thoughts?
I updated my info, BTW.
Old Mar 7, 2018 | 04:19 PM
Purchase at least four 15 amp fuses. Key out of ign., remove and replace fuse #5.
Open hood and locate the Coolant Cir. Pump near the battery and remove the two wire connector. Start the truck and shut it off (maybe a few times) and see if the fuse blows.
Old Mar 7, 2018 | 05:13 PM
Bill Lewis's Avatar
2002 ml320
I tried a second one of the five 15A fuses I bought and walked slo-mo through ignition and startup. It blew while I was admiring the full set of warning/indicator lights. I will do your suggested second step either shortly or tomorrow morning. We're visiting family at the moment and need to respect their schedule.
Thanks for the walk-through, and the good news is that I still have three good fuses. The parts house is nearby too.
Old Mar 8, 2018 | 02:33 PM
Bill Lewis's Avatar
2002 ml320
Maj. Dundee, I haven't been able to get the 2-wire lead off the coolant circulating pump. I got the wire off the rubber cord end, but I haven't been able to get the cord end off the pump. Is there a trick to that, or a step I'm missing?
Old Mar 8, 2018 | 02:56 PM
Take a close up photo of the connector and post it.
Old Mar 8, 2018 | 05:51 PM
Bill Lewis's Avatar
2002 ml320
Images
From below, side.
From above.
I took several. I don't know if any of them is worthwhile. Here are a couple.
Old Mar 9, 2018 | 03:58 AM
Your pump looks like it's been repaired. The pump has a thick rubber cushion around it and the cushion sits on a bracket.
Pull the motor with the rubber cushion off of the bracket and press the metal clip inwards and at the same time pull off the connector.
Old Aug 12, 2025 | 03:59 PM
ChrisVannoy's Avatar
2002 Cl500
mine is doing this also now any ideas? What was the fix? Thank you in advance
