Activated Satellite Radio - Not Working
BMW 530
Just leased a 2008 ML550. Activated the satellite radio on Monday 2/5/08 and as of today, it does not work. (the radio is not acquiring any signal). When I press the SAT button, the weather channel comes up (Ch 184). Called Sirius and they mentioned I should bring the truck back to the dealer.
Any help on this issue before I go to the dealer. Thanks.
Initial activation can be tricky as you need to have the car out where it can see the satellite and active when the activation signal 'turns' the radio on. The signal is broadcast frequently right after activation then very rarely later on based on how I understand it. The weather channel is one of the free channels. It would seem the RADIO is working fine, it just doesn't think it is activated.
Check the ESN they have on record (I assume you had the radio system on and in clear sky's etc when activating the first time) - chances are your ESN was recorded wrong.. I think it was channel 0 would show you the ESN of the radio that is the one that needs to be used
tk
tk
2008 ML550; 2005 SLK55
tk
tk
2005 C-230 Sport Sedan
BMW 530
Have you logged into Sirius.com and clicked the button that resends the activation signal to your car?
I used cschmelz suggestion and it worked (truck outside, SAT radio on to Ch 184 and then called Sirius to activate.).
I used Sirius.com for the initial activation. It was Monday morning and the truck was park in the garage. When I tried to use the SAT radio on Wednesday, I couldn't get any channels. That's when I called Sirius 800#.
Thanks again.
I saw where XM and Sirius radio finally merged. Sure hope the song selections merged as I'm really tired of hearing the same stuff over and over. I have Sirius but I've always thought XM song selection was better. Of course those with XM probably think otherwise.
- FD
Last edited by Floobydust; 07-26-2008 at 09:24 AM. Reason: corrected some typos . . should post so early in the AM
