Navigation AMG Startup Screen
Old Apr 15, 2010 | 04:37 PM
gmdebruyn's Avatar
2005 E55, 2010 ML350
For the ML350/2010 - with the current nav system, are there some hacks where we can set the startup screen to show the AMG symbol?
When I bought my E55, it didn't have that set, so I had to do the 357 Nav yes/no trick to get it to show.
for the current navigation system, is there a current method to do this?
Old Apr 15, 2010 | 07:22 PM
roadrutz's Avatar
'09 ML550
From the many posts on the topic, I gather than the 2009/2010 NAV systems are a lot less hackable than before. I have yet to see a post on this or any other forum that shows how to get into service menus.
Old Apr 16, 2010 | 12:46 AM
egtgrant's Avatar
2010 ML63
Getting into the service menu is pretty straight forward. The method that works on my '10 ml63 is:
hit the nav button
Once in nav mode, hold phone hang-up/*/6 (3 buttons) at the same time until the engineering menu comes up.
I haven't noticed the AMG start-up screen on my vehicle (despite being an AMG) and didn't see an option to toggle this when I poked around the engineering menu a few days ago.
Old Apr 16, 2010 | 01:09 AM
gmdebruyn's Avatar
thank you. when i got my AMG, the AMG startup screen wasn't there either. that is what prompted me to research it at that time. i'll play around and report back.
Old Apr 16, 2010 | 02:45 AM
egtgrant's Avatar
2010 ML63
I'm definitely looking forward to seeing what you find. I had no real intent when I was poking around the system the other day and could have easily overlooked this feature.
I really only became aware that some have the AMG splash screen (on older models?) more recently.
Old Apr 16, 2010 | 10:44 AM
roadrutz's Avatar
'09 ML550
Originally Posted by egtgrant
hit the nav button
Thanks! That worked on my 2009 ML550 as well. But I couldn't find anything I wanted, in particular: (a) change the colour scheme on the display; (b) change the rate volume increases with speed. On my X5 I could do both of these.
Out of interest, where did you find out how to get into the engineering menu?
Old Apr 16, 2010 | 12:44 PM
gmdebruyn's Avatar
i'll report back at lunch time. too much going on atm.
for my e55, there were two menus, the engineering menu where you could change the NAV voice, and the service menu where you cold change the keyboard layout/logo/etc.
i'm hoping its all in one menu this time, but if its not, any clues as how you derived this back door? if this doesn't work, there has to be another menu.
Old Apr 16, 2010 | 03:35 PM
gmdebruyn's Avatar
hit the nav button
success! i went into the engineering menu and poked around, but there was nothing fun to modify. in my AMG you could change the language to British English and the nav lady would have a nicer accent. but it seems that is not the case here.
in my AMG, this same menu was reached when you were on the Nav screen.
in my AMG, the other screen was reached by some button combinations, while you were on the Audio screen. we'll have to research more, but please let me know if you find anything.
Old Apr 16, 2010 | 07:30 PM
egtgrant's Avatar
2010 ML63
I found it over on the other forum (Benzworld.org).
Old Apr 17, 2010 | 01:20 AM
egtgrant's Avatar
2010 ML63
I did a bit more research and I think we may be up a creek as far as making these types of changes in newer models (more or less >2008).
It appears that many of the 'cool' functions that used to be available via the service/engineering menu (are these the same?) have been stripped from newer models. Specifically, it appears that you used to be able to configure the start-up screen, enable vehicle in motion playback for the DVD, and some other minor functions through the service menu.
By and large, the consensus appears to be that these functions have now been removed entirely, or are now only available via a dealer with SDS.
I hope to be corrected on these points... However, at this point, I haven't been able to find supporting evidence to the contrary.
Old May 15, 2011 | 12:05 AM
mark_lindholm's Avatar
2009 E320
2009 E320 getting into Engineering mode
Engineering mode is three buttons at once:
Hangup * 6
However the hangup button is the one down by the command screen, NOT the one on the steering wheel.
Old Jun 8, 2011 | 04:22 AM
JJKK's Avatar
ML350
has anyone found out if it's possible to have that AMG logo at start up?
Old Jun 8, 2011 | 02:30 PM
Brisk335's Avatar
///M5 Beast
Yea i would be interested in this aswell, cant seem to get it on my ML63.
Old Jul 2, 2013 | 02:52 AM
Hakop's Avatar
2005 CL55
Any1 know if it's possible to get the Amg logo on startup on a w215 2005 cl55 ?
