AZN Optics 194 City lights for your W164
Old Sep 2, 2015 | 01:38 AM
  #76
AZN Optics's Avatar
SPONSOR/MBworld Guru
AZN Optics is now offering next generation Morimoto XB35 HID conversion kits. Available for order on our site www.aznoptics.com or PM us for more details.
Old Oct 1, 2015 | 12:56 PM
  #77
AZN Optics's Avatar
bump
Old Oct 2, 2015 | 08:52 PM
  #78
SunnyT's Avatar
2019 S560 Maybach
How about any new versions of V3, or something that will work in the 06ML model? (V4 had issues)
I keep get dying/blinking diodes with the V3. Not sure why they keep dying (2nd replacement)
Old Oct 2, 2015 | 08:56 PM
  #79
AZN Optics's Avatar
V5 are much better than previous gen units. There's been some big leaps in technology we've been able to incorporate into our design including the latest COB based diodes which are brighter, cooler burning, and more durable as well as the constant current IC drives which help regulate current to safeguard low-mid level surging events. Since it's been released, we haven't had any unit fail from usage yet.
Old Oct 2, 2015 | 09:17 PM
  #80
SunnyT's Avatar
2019 S560 Maybach
Thanks for the quick reply. I just sent you a PM with a couple questions about the V5
Old Oct 6, 2015 | 05:58 PM
  #81
SunnyT's Avatar
2019 S560 Maybach
Just had another wonderful buying experience from AZN Optics and wanted to share some install pics from their latest V5 LED bulb. (I upgraded from their V3 model)
I installed these in my 06 ML500.
It's still bright out, so I will upload night pics at a later time.
** All pics were taken with my phone **
- Here is the packaging of how the product arrives. Clearly a sturdy box, and the LEDs are tapped to the bottom in a vacuum sealed bag so that they don't move and risk being damaged. Very efficient packaging.
- Here are the bulbs, side by side. V3 on the left and V5 on the right. Clearly a significant upgrade!
- Here is where I removed one of the V3s from the housing. It shows how the bulb sits in the socket, both on and off. (I use the gloves when dealing with the lights, as I don't want to get any sort of oils from my skin onto the connectors)
- Here is the V3 bulb in the light housing on the left side, which I haven't removed yet. I will use it to contrast the V5 installed look in the upcoming pics.
- Here you have the V5 installed in the light socket. I will say that this was a lot harder to get in than the V3. I was very conscious about the small tabs that are in the center of the connectors that slide into the socket. You can see what I'm talking about in the side by side picture above. (I found slight left/right wiggles helped slip it in without having to use brute force)
- The V5 is now installed back in the light housing and you can see what it looks like up close, both on and off.
- These are various pictures of the V5 installed and ON, both by itself and together with various other lights that the car has. This car does have active curve lights and has Bi-Xenon Low beam lights. (Fog lights, Low beam, High beam can all be seen in these)
- These were taken in my garage, some with the overhead light on and some off. I tried to illustrate that the color is very close to the Bi-Xenon, really can't tell the difference when you're 3ft. away. The blueish hue is only evident in the pictures, eyes can't really pick up the difference, I even asked my neighbor and he couldn't see a difference in person either.
- Here I moved the car outside. You can really see the blueish hue disappear and the light looks clean and crisp. Even though it's still bright outside you can clearly tell that the bulbs are on.
- These are also a combination of shots with varying lights ON. One with just the LEDs (with a close up), and the other with Low beams and Fogs as well.
Thanks for viewing my pics and install!!
Again, I'm really pumped about the new V5 LEDs, definitely and upgrade from the last V3 I was previously running.
If you have any questions about the install (removal/install techniques) I'll do my best to answer them.
Old Oct 6, 2015 | 08:40 PM
  #82
SunnyT's Avatar
2019 S560 Maybach
Got some night shots, again taken only with my phone.
The difference is AMAZING. They are actually a lot brighter than I thought. Although, to my interpretation, they didn't shoot the light forward as much as the V3, they make up for it by filling the whole area with light. These suckers are bright!
Here's how ONLY THE V5s light up the wall about 6ft. away:
(Only other source of light was a street light ~35ft. away)
OFF
ON
I wouldn't believe it if I didn't see it! The V5s are remarkable.
Front with only V5 ON:
Front with V5 and Headlight ON:
Old Oct 9, 2015 | 01:31 PM
  #83
AZN Optics's Avatar
Looks great! Thanks for the review. Glad you enjoy. Please keep us in mind for any other lighting project
Old Nov 3, 2015 | 02:47 AM
  #84
Borko's Avatar
ML
Which ones did you buy? The 4300 or the 5000?
Old Nov 3, 2015 | 02:59 AM
  #85
AZN Optics's Avatar
Those are the 5000k model.
Old Nov 4, 2015 | 12:19 AM
  #86
yister's Avatar
Ml350
Not to jack this thread, but I tried a set from azn and a set from mtec in the past. The older set from Azn was terrible color(new ones look better), and the one from mtec burnt out. Got tired of the city all together and decided to just get rid of it.
Looks a lot better and cleaner, also works as blinker as well.
Old Nov 4, 2015 | 12:50 AM
  #87
AZN Optics's Avatar
Looks good. How long ago did you purchase one of our units? Couldn't find your username in any message or reference to a purchase? Curious about the color issue you had and which version of our older units you used.
Old Nov 18, 2015 | 11:10 PM
  #88
WEBSRFR's Avatar
Tesla Model S P100D
Hi We have a 2011 ML350 and my biggest issue with the car is how the Halogen lights are so dim at night especially compared to the HID lights of our other cars.
What do you recommend for improving the Halogen lights that came with the ML350? Do you have a plug-in replacement that is LED or HID based? Is it an easy swap?
Old Nov 18, 2015 | 11:16 PM
  #89
AZN Optics's Avatar
We can definitely set you up proper. You'll want an H7 HID conversion kit. We carry top end Morimoto kits that are simple plug and play units. Offered in 5000k pure white and 6000k white with a slight bluish hue. Shoot us a PM or email us directly at aznoptics@gmail.com and we'll get the process rolling.
Old Dec 14, 2015 | 06:36 PM
  #90
AZN Optics's Avatar
bump
Working on adapting our V5 design to festoon models which should be available January.
Old Dec 16, 2015 | 02:21 PM
  #91
Borko's Avatar
ML
For '08+ ? No error codes?
Old Dec 16, 2015 | 02:52 PM
  #92
AZN Optics's Avatar
That's the hope. Need to get some ML test vehicles.
Old Dec 20, 2015 | 09:34 AM
  #93
STLML350's Avatar
ML350 Blutec
We have a 2010 , what does the HID conversion cost.
Old Dec 20, 2015 | 11:34 AM
  #94
AZN Optics's Avatar
Morimoto H7 HID conversion kit retails $150/kit. Kit includes bulbs, ballasts, wiring loom, igniters, and canbus cancellers for both headlights. Morimoto kit comes with a 5 year warranty and comes in 5000k (pure white) or 6000k (white with a slight bluish hue).
Old Dec 28, 2015 | 03:52 AM
  #95
plasmid's Avatar
2007 MB ML350
Just ordered 194 leds for my parking and side markers. Thanks!
Old Jan 18, 2016 | 03:22 AM
  #96
Borko's Avatar
ML
How is the work going on the festoon models?
Old Jan 18, 2016 | 12:45 PM
  #97
AZN Optics's Avatar
For your plates? Not quite that simple unfortunately. For there to be enough resistance built in to the unit, there'd be too much heat generated which would damage the surrounding components. We're working it though.
Old Mar 16, 2016 | 12:56 AM
  #98
AZN Optics's Avatar
Have halogen reflectors and don't want to blind oncoming traffic with an HID conversion? Good call! We also carry full line of Morimoto Bi-Xenon projector retrofit kits from FX-R stage III and IV to Morimoto Mini Stage III!
Old Mar 22, 2016 | 09:19 PM
  #99
prsguy's Avatar
1999 ML430 & 2011 ML550
Got my set of leds yesterday and installed them on my 2011 ML550 today. Great improvement over the stock bulbs. Love 'em!
Old Mar 22, 2016 | 11:27 PM
  #100
AZN Optics's Avatar
Originally Posted by prsguy
Got my set of leds yesterday and installed them today. Great improvement over the stock bulbs. Love 'em!
Glad you enjoy. Post some pics!
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
