2012 ML350 bluetec error code 106100 and 153900
Does NOX sensor available in the market other than MB Service Center ?
106100 upper limit
143700 short circuit pin 2 of 87
11B300 Component M3 fuel pump short to ground
11EC00 Starter control has short to ground
126800 Y77/1 chage pressure position is faulty
108800 Signal from B6/1 ( camshaft hall sensor ) is faulty
Lots to digest there, and I need to research more. But would like to hear from the smart guys about the 106100.
I did inspect the Adblue injector at the exhaust. Under magnification it was clean.
Any suggestions ?
106100 upper limit
Any suggestions ?
read on other treads it is recommended to change the up-stream then the down stream. Someone reported dealer changed one of them to no help and charged thru the roof and called for the car to go back to change the second sensor. Person was looking for help just as many others since we all know the rabbit hole dealers get you in. Never he reported back about the second sensor nor about a fix. Mine has 57k miles with no other emission problems since 42k miles purchased.
Help would be greatly appreciate it.
