2008 ML550 - Slight creeping/squeaking noise
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
I have a very slight creeping/squeaking noise while going over parking lot speed bumps, which appears to be coming from the front passenger side.
The truck has 105k miles on it, so what do you think will need some attention?
- Shocks
- Control Arms
- Bushings
Any help is greatly appreciated, thank you!
- Shocks
- Control Arms
- Bushings
Received 1,486 Likes
This place is a joke.
Check the front upper control arm bushings. I'm currently replacing mine on the ML63 but my ML350 will get complete new arms due to mileage. The bushings tear inside and the squeaking is the sound of rubber sliding against itself.
Would this possibly also account for the truck feeling somewhat "wobbly/wobbling" while driving over pavement which is not smooth, pavement with some imperfections? Feels like the truck wobbles a bit up and down, ................. not sure how to really describe it.
I don't think I am quite there just yet. I have been driving E class or S Class with Sports Suspension for the last years. Maybe I need to get used to driving a "truck" vs. a sedan, which sits much lower to the ground and has therefore a stiffer ride.
Wondering if I need to get used to driving this ML, and that the ride is maybe what it is? I possibly may be too picky based on my previous cars?
The noise over the speed bump is not very obvious, I really have to listen for it.
As a matter of fact, I dropped the truck off this morning at my trustworthy mechanic to investigate and address the issue.
The verdict from my trustworthy Indy, truck needs to following:
- Lower Control Arm Bushings (Uppers are ok)
- Sway Bar Bushings
- Front Shocks
All this shall explain why the truck felt somewhat "wobbly"
- Sway Bar Bushings
- Front Shocks
Finally got around to replacing both front upper control arms ($78/pair Ebay) on my '08 ML350 w/176k miles, and wow, what a difference in ride quality and all the creaking noise over bumps is gone.
