2011 ML350 BT, diesel smell, detonation sound
My 2011 ML350 BT 80K miles, had rattle noise on acceleration and was tracked to the wastegate veins in the Turbo and eventually replaced the whole turbo with brand new original Garett and was installed on the car. After the rattle noise is gone, more power was also obtained.
After a couple of days I started smelling diesel smell in the cabin and also noticed a sound on acceleration like detonation or “tapping” noise! When I open the hood and look closely I see light mist/smoke coming up from the right hand of the engine just underneath the air filter on that side, this wasn’t experienced before the turbo replacement.
I have read a lot about injectors leak on MBs, that actually kind of makes sense to me and explains the symptoms I’m experiencing, am l on the right track?
No CEL lights or codes at all on the SUV!
Any ideas, pointers would be appreciated.
Happy New Year Everyone!
thank you!
does anyone any diesel injector rebuild shop Toronto East or Durham Ontario that I can take my injectors to be checked/rebuild?
thanks.
thanks.
How do you check if the flaps are still attached to the grid and motor without dismantling the whole intake?
I have the resistor needed to cancel the whole mechanism of the flaps/actuator motor, is there value in doing this?
Thanks.
