Replacing bi-Xenon Headlights
M-Class (W164) 2007: ML350 4Matic Gas
Hello,
I am planning to replace my bi-xenon headlights. The replacements will be new OEM parts. I read on many sites that an ECU flashing will be needed in order to operate correctly.
Could you please provide more information about this? I was hoping it will be just a plug and play process.
Thanks!
Thanks!
Hello. I want to replace them because they are very dim. I think the projectors are not in good condition and therefore they are not projecting the light properly.
I have replaced recently the bulbs (phillips D2SC1) and there was a marginal improvement. Furthermore the cables etc seem to be ok. Hence I concluded that the projectors are the issue..
If you have any other suggestions please let me know
2006 R500
If you're handy with tools and feeling a bit adventurous, this is the better option: https://mbworld.org/forums/r-class-w...-retrofit.html
By the way, I have one more question. I see that the headlights are Bi-Xenon, which means that the xenon bulb should act as a high/low beam. However I noticed that when I turn on the high beams, then a seperate "high beam" bulb turns on (which is a halogen bulb). Do I miss something? Is this what was supposed to happen?
2006 R500
Yes, that is perfectly normal. The regular halogen projector option does not have a high beam function, making the separate high beam bulb and reflector necessary. Rather than having two different style headlights, the halogen projector was replaced with a bi-xenon projector. The bi-xenon cars therefore have two sets of high beams: the xenon high beams and the halogen high beams.
Projector retrofits are the way to go. X164 headlights are easy to open and EVOX-R projectors drop in with a minor amount of work. Other projectors will work too, but require more trimming/fitting. Huge improvement over old projectors with burned bowls.
So so much easier the replace bi zenons with plug n play LEDs that run off your standard ballast. Instant on, More Lumens and a variety of different Kelvin colours to choose from. I like 5000K. Whiter without being blueish. Cheap easy and effective. I also run LED Highbeams and parking lights as well as reversing lights, brake lights and rear indicators.
2006 R500
Also, LEDs will do nothing to solve the burned projector bowls that is common on Mercedes of this era.
The following 2 users liked this post by Tsumi:
BlackML550 (02-25-2023),
EWT (02-24-2023)
Never listen to this kind of advice, nor should you give it out. There is no LED bulb that can match the output of high quality xenon bulbs, nor are the optics designed to properly accommodate (there's more to headlights than just being bright). The only only time I would ever be okay with LEDs bulbs for headlights is in the high beams. Otherwise, if you want LEDs, do a proper retrofit with LED projectors like the Morimoto M-LED projectors. They're more expensive and designed differently for a reason.
If your reflector is burnt then that's needs replacing 1st. However I stand by every thing I said and done to my own car. LEDs use less power, produce less heat but produce more light. Here we are in 2023. Show me a car that uses HIDs. None. Why is that? Because there not as good as modern LEDs which use less power, produce less heat, last forever and cheaper to make and produce more lumens.
2006 R500
Also, I would not say car manufacturers are using LEDs because they're better than HID systems. Cheaper, yes, but better? Show me an OEM LED system that can outperform a proper bi-xenon 55 watt projector with Philips or Osram bulbs. Most LED headlights are about as bright as 35 watt HID bi-xenon systems using generic HID bulbs because legally they don't need to be much brighter than that. Unlike HIDs, LEDs cannot be "beefed up" using better bulbs or higher output ballasts.
LEDs also suffer from heat degredation, where if they're not kept cool enough, their output will dim over time as the heat builds up. This is especially true for LED bulb assemblies. The dimming is almost imperceptible because it happens slowly over time.
You will also notice that all modern cars that use LEDs have dedicated LED housings. They're not simply using LED bulbs in traditional reflector or projector housings. If they're in projector housings, it's a specialized LED projector design, not one where you stick a bulb in the back like HID and halogen projectors. Also, I would not say car manufacturers are using LEDs because they're better than HID systems. Cheaper, yes, but better? Show me an OEM LED system that can outperform a proper bi-xenon 55 watt projector with Philips or Osram bulbs. Most LED headlights are about as bright as 35 watt HID bi-xenon systems using generic HID bulbs because legally they don't need to be much brighter than that. Unlike HIDs, LEDs cannot be "beefed up" using better bulbs or higher output ballasts. LEDs also suffer from heat degredation, where if they're not kept cool enough, their output will dim over time as the heat builds up. This is especially true for LED bulb assemblies. The dimming is almost imperceptible because it happens slowly over time.
2006 R500
My headlight LEDs are running off the standard 35W ballast and produce more lumens than my standard HIDs did with Osram globes and if I run higher ballasts 50, 75, 100 then I guarantee the LEDs that I would fit would also be superior to their HID Equivalents. And if they do dim with time. Ill chuck them in the bin and get the latest tech. No problem. Im not hear for a battle. Just solutions. If you dont want to use new technology. Don't . Its that simple.
https://blog.headlightrevolution.com...ghter-than-hid
https://www.reddit.com/r/cars/commen...d_vs_hidxenon/
Like I have indicated, I have nothing against LEDs, if done correctly. And by correctly, I mean using proper LED projectors, not shoving LED bulbs into a halogen or HID projector (they seem to do okay in halogen reflectors). But hey, if you want the latest and greatest, why aren't you going lasers? https://blog.theretrofitsource.com/h...s-hid-vs-laser
You can believe whatever floats your boat. I'm here to make sure that your feelings and subjective opinions are countered with proper information. I would dig up more but sadly lots of the testing on HIDplanet is lost with the website being down. There's also a reason why none of the premium LED bulb makers have D-bulb variants. https://blog.headlightrevolution.com...d_vs_hidxenon/ Like I have indicated, I have nothing against LEDs, if done correctly. And by correctly, I mean using proper LED projectors, not shoving LED bulbs into a halogen or HID projector (they seem to do okay in halogen reflectors). But hey, if you want the latest and greatest, why aren't you going lasers? https://blog.theretrofitsource.com/h...s-hid-vs-laser
2006 R500
Because you get **** poor light distribution in the low beam and bi-xenon projectors, which is what really matters for 90% of nighttime driving scenarios. What you feel what you are happy with and what is good objectively can be two very different things. For example, lots of people run with fog lights on because they think it lights up the road better. What it actually does is dump a lot of light on the foreground and compromises long distance vision because the pupils constrict to reduce the amount of light coming in.
2011 E550 - 4Matic, 2008 ML550
Ill pipe up too- I have LED D1s bulbs in both my Mercedes - and he is correct - they work better than HID - brighter - whiter - still throw distance as needed and the added bonus of instant on too...
Also the beam pattern (assuming you get a good bulb) is actually better with regards to focus and cut off...
They are that good these days - a year ago I would of said stay away - but I have been more than happy and wont go back to HIDs.
I have a lot of HID bulbs if you want some of them - but LED will outshine!
I'd say try it before you make comments on something you have not tried - you MIGHT actually like it...
Cheers
Cheers
