About Steering Pump A0054662201
Old Feb 17, 2022 | 12:39 PM
grkmspr's Avatar
ML350 - 2007 164.186
Hello,
i have a steering problem since bought a car. i will replace pump but i confused about this situation.
i have 213 parametric steering.
MB epc says if you have 213 you need to use, 0054664201 but also says chassis number starts A53xxxx and after 07/2009year, my vin is A29xxx . and understand i need to use 0054662201 pump. but why they didn't wrote 213 parametric steering.
(also i check 0054664201 pulley is 7pk, 0054662201 is 6pk)
well the true pump is 0054662201 for me right?
Old Feb 18, 2022 | 08:31 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
What is the steering problem you are having?
Old Feb 19, 2022 | 07:17 AM
grkmspr's Avatar
my steering is very stiff, i changed pump 2 times but there is no diffrence.
my Y10 selenoid valve working normally.
i changed oil reservoir.
Old Feb 20, 2022 | 04:21 AM
Then in all probability you have a problem with the Y10 SPS Solenoid Valve.
You must scan for codes in the ESP-BAS Module WITH A SCANNER, a code reader will not do.
File Type: pdf
Old Feb 20, 2022 | 04:52 AM
grkmspr's Avatar
i checked there is no problem. also control it with Xentry, 100ma and 1000ma has difference. 100ma steering can't turn , 1000ma steering ligher than 100ma but still heavy.
I suspect the Steering Pressure Hose because there is noise inside the car when turning the steering wheel. However, when I open the hood, that sound seems to come from the hoses rather than the pump.
Old Feb 20, 2022 | 05:42 AM
So what you are saying is there are no codes in the ESP-BAS module, correct?
Have you scanned for codes in all modules?
What country do you reside in? Please update your profile to include that.
Old Feb 20, 2022 | 05:57 AM
grkmspr's Avatar
I'm in the Kazakhstan. My car is european.
In ESP i have only 2 codes.
ESP - Electronic Stability Program 2 problems exist
1.6001 The Supply Voltage Of The Control Unit Is Too Low(Undervoltage).
Stored
2. 7256 CAN Signal 'Cruise Control Lever' From Control Unit N80(Steering Column Module) Is Implausible.
Stored
Old Feb 20, 2022 | 06:20 AM
I can't understand why you ignored those codes. Did you research those codes through Xentry, if you have it?
Is Kazakhstan right or left hand drive?
Old Feb 20, 2022 | 06:27 AM
grkmspr's Avatar
Left hand drive. i didn't remember but xentry didn't have a suggestion for a solution for this two DTC.
ABS, ESP and Cruise control works very good.
Battery voltage is not bad i think. When its very cold outside it's charge will low but there is -20 celcius outside. i think these codes stored and come when battery voltage is low.
Old Feb 20, 2022 | 07:22 AM
I had the same prob. a month ago. Installed a new battery and the problem was gone. If on a very cold day, your batt. is below 11v, you need a new batt.
Code 6001, which is an EVENT code, refers to cir.30 return flow pump N47-5.
Old Feb 20, 2022 | 07:26 AM
Also check fuse #115 in F58.
File Type: pdf
Old Feb 20, 2022 | 08:05 AM
grkmspr's Avatar
Heavy steering problem gone, or ESP fault code has gone? i will check the fuse but i need to check it before. i will check again. thx
Old Feb 20, 2022 | 08:24 AM
I don't understand. How did the codes disappear?
Old Feb 20, 2022 | 08:29 AM
grkmspr's Avatar
After replacing the battery, did the ESP related fault codes (DTC 6001 / 7256) go away or was the steering stiffness problem solved? Do you have a steering stiffness problem month ago?
Old Feb 20, 2022 | 08:43 AM
I do not understand what you are saying. It's cryptic.
Old Feb 20, 2022 | 08:53 AM
grkmspr's Avatar
you said, "i had the same problem a month ago", i try to understand what is your problem. steering stiffness or esp fault codes?
Old Feb 20, 2022 | 08:59 AM
My prob. had nothing to do with your problem, it was just a defective battery.
Did you try deleting those 2 codes?
Old Apr 8, 2022 | 07:49 AM
grkmspr's Avatar
i bought MEYLE Steering Pump and now its better. i can drive car with one hand and also parking with one hand. but i think it still heavier than other cars. or maybe because of SUV (high vehicle) it is heavier then sedan cars.
