Rear Brake rotor/pad dilemma
Last summer took my W164 to get the rear brake rotors/pads replaced.
Took the SUV into the shop last week for some AC work and I had them inspect my brakes to see if the fronts needed replacing.
Mechanic comes back and says rear brake rotor/pads needs replacing, he says wait till the sensor goes off to replace them.
So I didn't tell him they were replaced last summer, can someone already spot the dilemma?
So either the shop last year didn't replace them and just charged me OR the latest mechanic is BS'ing me. The mechanic from last year closed up shop a few months back (he had been at that location for 11 years) so I cannot ask him what the deal was.
I want to measure them myself but can I do this with the tires still on? If they are new rotors they shouldn't have any lip since it hasn't even been a year yet correct?
Ok so I decided to take a look myself.
The rear rotor doesn't have any lip at all compared to the fronts which definitely have a lip.
Below is a pic of the rear brake pad which looks pretty thick to me, correct?
so I'll give the most recent mechanic the benefit of the doubt and assume he meant to say the fronts (even though I asked him several times if the rears really needed replacing)
below is the driver's side front brake pad
Do it the right way and measure the pad thickness using a tool from an auto parts store. There is no dilemma here.
Ignore what mechanics tell you, produce the information yourself. You tell them what to do, not the other way round.
If you have taken the photos correctly, the pads have enough material on them.
As a rotor wears away, the very outside of the surface remains, as the pads don’t touch that area. This remaining area is often called a lip.
This lip is pretty useful, as it can show 1 mm of wear and the assumption should be there is 1 mm wear on the back side … and maximum permitted wear is 2 mm … so, time for new rotors.
Condition of pads doesn’t matter at this point because old pads on new rotors is not permitted. Time for new pads too.
Of course you have to remove the caliper holder to get the rotor off … and Mercedes specifies the screws that mount the holder be replaced, not reused. Order new screws, too.
I'll wait for the front sensor to go off then I'll have both rotors/pad replaced
chassis (03-29-2022)
2006 ML320 CDI (2 of) and 2008 GL320
Absolutely agree that you need to look at both inner and outer pads. If the caliper slides aren’t lubed (on pad change) it won’t slide properly and one pad will rub and wear quicker. Had a case recently when inner was nearly shot but outer was great (still had bevels)
I have put new discs on nearly new pads when a car had low pads (which I had in stock) but needed to wait a few months for discs to come in stock (covid delay in Australia). But obviously not ideal
Showbox jiofi.local.html tplinklogin
