2013 US order info
My SA said his MY13 m-class order bank opened up on April 7. MB's official memo said April 15.
The actual pricing of many of the items may take until production starts in June, he said. Delivery is unlikely until end of July/early August.
My SA is currently finding out if I can special order it without the standard equipment running boards. I had those on my MY07 and didn't like how they would dirty my pant leg. I think any ML with AIRMATIC looks better without them, since it sits lower.
I'm still debating on the interior, which wood trim and leather, and still have some time to change my mind. Might go with the Brown Satin Ash or Anthracite Poplar instead of Burl Walnut.
BTW: The posting by jean7of9 earlier was of the Canadian standard equipment and options. This pdf is for the US version of the ML550.
I agree...I don't see why the AMG is so much more expensive, although the AMG has a lot of standard stuff (like Active Curve), more heavy-duty breaks and the nicer interior. I really don't need the extra power or other stuff, but I do like the body shape on the AMG that the 550 does get closer to. The big difference is in the front wheel wells, which flare out on the AMG, giving it a more aggressive stance with those wider 21 inch tires.
If you really want an MY13 550 but not risk getting bumped to an October delivery, I would go ahead an place your order now to ensure your top place in line. Dealers only have so much initial allocation. You should have at least a month to change it (i.e, before it goes into actual production), but your SA should be able give you more definitive advice.
I've attached a PDF of the listing of MY13 m-class for Canada that someone else posted earlier (I've renamed it). It doesn't have any pricing yet, though.
I think the must haves of the new options includes the Multi-contour seats. Like with my old MY12 X5 -- but in an even better way -- it extends out the bottom of the seat to give your legs more support and allows the sides bolsters to hold you firmer on the turns (although wish they were the active version). The new S-class has them if you want to go try them out.
Also, the Active Curve give you the AIRMATIC suspension that makes all the difference in ride as well as looks and safety. It can also supposedly improves your highway gas mileage, since the ML hunkers down at high speeds, causing less drag.
As for the price premium, it is actually very narrow on ML 550 vs ML 63 - compare to E 550 vs E 63! With the ML 63, you get standard ACTIVE CURVE ($5000), plus all the AMG goodies.
Other than the C 63, the ML 63 is hands-down the AMG "bargain".
You often felt squeezed in the multicountour seat? Sound like you didn't have it adjusted right. The whole purpose of the multicontour seat is that you can adjust it to your particular body shape and be 100% comfortable. Or did you have the Active version of the Multicontour seats before? In that case, unless you turn it off, it will indeed automatic squeeze your back a little whenever you hit an aggressive turn in order to keep you in place...or so I'm told. I never actually experienced it. Maybe someone else with actual experience of the active version can better enlighten us.
Also, with the Multicontour Seat on the new S-class, I notice when I tried it out the other day that you can only adjust the side bolsters via the COMMAND system...so it is not obvious like the other settings on the door. So, maybe you never set it correctly for yourself on your E-class.
Of course, if you feel well-fitted in W166 seats, then I guess there is less of a need during regular driving. But if you're going to get a ML63 with the ACTIVE CURVE standard, you're going to be finding yourself having fun taking turns 'corner flat.' When that happens, you might be wishing you had side bolsters that you could adjust to keep you little more firmly in place. Otherwise, it can strain your back...not to mention the comfort of your passenger if they don't have them. I'm only talking from experience of having the multicountour seat in my BMW X5, but I expect that M-class version basically works the same per the side bolsters.
Dealer looked at 2013 MB computer build pages for E and ML and they had options but no pricing. E and ML both showed July builds start 2013 models. Also, the official "vehicle spec" area would not open as we thought specs would include HP.
One mag had said the 350 gasser was built to be "turbo-ready" so I was even hoping this would be a sweet little turbo motor....
Oh well, just appreciate they bumped it up from 268 HP.
And yes, what's the point of twin turbos for only 30 more HP--seems nuts. Seems way low on HP bump over current NA motor.
"The bi-turbo V6 will work its way across the line-up in short order. I believe it will be coined a '400'. 350 would die, but you'll see a proliferation of 4-cylinder turbos... including diesel BlueTECs; ie: GLK 250, ML 250."
I wondering, what is the "EASY-PACK Power Tailgate" package as listed in that Canadian M-Class brochure? Is the power tailgate an option in Canada but standard in the U.S.?
Seems incomplete, though...no mention of Active Curve System, Soft Close Doors, and Power Passenger Seat with Memory. It does confirm mbrace2 will be available. But what is "2nd generation NTG 4.5 headunit?"
My SA informed me today that they can order all this, but the Mufti-Contour seats will delay my build until August (not the first factory run, but the second). But then if I wait, they cannot guarantee other options that I could get in the first run will still be available in the second. Is this messed up or what? What kind of disorganized business is MB running? Uggg....maybe I should just get another X5. Last year BMW delivered my custom ordered MY13 in just four weeks. If the ride wasn't so harsh, I'd order another one today.
