"Blind spot assist currently unavailable. See operator's manual"
Old Sep 12, 2013 | 09:21 AM
iamgort's Avatar
2013 Metallic Silver ML350
Hi all, my ML350 I've had for about 1.5 months now had this error message today when I was driving to work:
"Blind Spot Assist Currently Unavailable. See Operator's Manual"
initial searching seems this happens when you are towing something, but I am definitely not towing anything. Any other ideas what may cause this?
Old Sep 12, 2013 | 01:33 PM
awjenni's Avatar
2016 GLC 4Matic
Was it early morning with a bright sun, low in the sky, directly in front of you? The optics (actual cameras in the upper windshield apparatus, forward of the rear view mirror) in the lane keeping system will send you a similar message if a very bright light interferes with its ability to "see" the lane boundaries. I don't know if blind-spot-assist is part of the same system though.
AWJ
Old Sep 12, 2013 | 01:49 PM
iamgort's Avatar
Hmm not particularly bright, no different than most mornings' commute.
Old Sep 12, 2013 | 06:19 PM
balticgreen's Avatar
2014 GLK250 BlueTEC, 2012 BMW 335is Conv.
Blind Spot Assist doesn't use cameras; it uses radar.
Old Sep 12, 2013 | 10:58 PM
twodivers's Avatar
'15 GL350 Bluetec
I have had this occur in the past, but only during very heavy rainstorms, when, apparently the radar is hampered. I believe is may also be caused by excessive dirt build-up over the radar units. Hope that helps.
Old Sep 13, 2013 | 01:28 PM
F18BEN's Avatar
Veteran: Army
2026 BMW 550e X DRIVE, 2024 GLE 450e SUV
BLIND SPOT ASSIST INOPERATIVE
I'm currently having the same proble. BLIND SPOT ASSIST INOPERATIVE warning. This started right after my B service. Dealer is checking it out. It is enabled in the command directory. My car is clean, so that rules out dirt on the radar sensors.
Old Sep 13, 2013 | 01:31 PM
iamgort's Avatar
It may have to do with my installation of Automatic combined with updating to the latest ios 7 GM build. I reinstalled the phone app and reinstalled the automatic device and it started working again. Will monitor closely and see if it happens again.
Old Sep 14, 2013 | 01:08 PM
F18BEN's Avatar
Veteran: Army
Now along with blind spot assist inoperative, My turn indicators stopped working. I'm dropping car off for service today. My dealer ordered new sensors for the blind spot assist.
Old Sep 14, 2013 | 03:10 PM
dougiebear's Avatar
2013 ML BLUETEC JULY 31
This has happened a couple times but goes away after restart
Old Sep 19, 2013 | 08:10 AM
F18BEN's Avatar
Veteran: Army
Dealer replaced the rear sensors and the problem is resolved.. It seems that your turn indicators are tied in with the blind spot assist and when it goes you lose them both....
Old Sep 19, 2013 | 08:23 PM
F18BEN's Avatar
Veteran: Army
Problem came back today after changing the sensors. Back to the dealer tomorrow.
Old Sep 20, 2013 | 11:18 AM
Oh my goodness. I hope they get this figured out for you.
Blind Spot Assist and turn signals are connected at least in software because when the car senses something in your blind spot and you activate the signal in that direction, the car warns you audibly. It seems a little strange that a failure in one would completely knock out the other one, though.
Sorry, don't know why that double-posted. I don't seem to be able to delete the extra post.
Old Oct 5, 2013 | 06:04 PM
F18BEN's Avatar
Veteran: Army
Problem was the steering wheel module. They replaced it. When the turn indicators are inoperative it throws off the blind spot asist. Problem finally solved.
Old Mar 13, 2014 | 02:29 PM
gi1mo2's Avatar
glk250
Similar problem with GLK250
I am having similar problems with my GLK250 on the Blind Spot assist. Dealer has ordered new sensors (on backorder). I do not seem to have issues with my turn signals, but I will monitor.
Old Mar 12, 2015 | 05:02 PM
MzGee93's Avatar
2010 E350 Sports Sedan
Same Problem
I have a 2012 CLS550. I hit a pothole last week and got a front driver's side flat tire. 2 days later Blind Spot Assist Inoperative. Got a new tire but the blind spot assist is still out. Got an appointment with the dealer on Monday 3/23
Last edited by MzGee93; Mar 12, 2015 at 05:04 PM. Reason: left out car model and year
Old Mar 13, 2015 | 12:56 AM
MannyS430's Avatar
2014 ML 350 bluetec
i am assuming this is all covered under the factory warranty. its issues like this that makes me want to get an extended warranty, but I believe the extended warranty does not cover all these gadgets.
