NEED AN MB TECH
Old Jan 2, 2015 | 04:29 PM
greasykid's Avatar
2015, ML250 BlueTEC
NEED AN MB TECH
If you are an MB TECH pls pm me. Just a quick question. Thx.
Old Jan 2, 2015 | 09:17 PM
DUTCH's Avatar
2000 MB G500 NMLE, 2015 Audi Q7 3.0 TDI Prestige
I'd be willing to bet you can get as good or better answer to your question on one of the forums as compared to a MB tech. However, it's your choice.
Old Jan 3, 2015 | 10:04 AM
greasykid's Avatar
2015, ML250 BlueTEC
TECH answers re lights.
So far no answer to this. How do we activate "cornering lights" in Xenons on ML. Can this be done? Previous post states that an empty bulb socket is in the lamp assembly. Cannot see that in mine.
Glad to get positive answer from any source.
Old Jan 3, 2015 | 10:10 AM
DUTCH's Avatar
If you have the Xenons, the headlights will follow the position of the steering wheel when the headlight switch is in the Auto position. This is from page 125 of the 2014 Owners Manual:
Old Jan 3, 2015 | 10:29 AM
greasykid's Avatar
2015, ML250 BlueTEC
Xenons
Understand. Looking for CORNERING LIGHTS.
Old Jan 3, 2015 | 10:37 AM
DUTCH's Avatar
That's what I was describing. See the image added to my edited message above, specifically the upper right corner.
Old Jan 3, 2015 | 12:03 PM
greasykid's Avatar
2015, ML250 BlueTEC
More Cornering Lights
Whatever you say. All I know is that my Lighting Package has NO cornering lights.
Old Jan 3, 2015 | 01:24 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
MB did not put that option on our vehicle in NA...discussed in depth prior..bottom line..there isn't any
Old Jan 3, 2015 | 01:26 PM
Bruce_Benz's Avatar
ML 350
I am reasonably certain that I saw a thread about this very issue somewhere on the forum when I was searching the Bixenon lighting package. Apparently there is a disconnect from what the manual says compared to how the vehicle is actually equipped. From what I gleaned, cornering lights are only on the European variant. They don't exist on U.S. vehicles, ostensibly because they are non DOT compliant.
If you search diligently enough, I think you will find the thread. Good luck!
Old Jan 3, 2015 | 01:28 PM
Nanook's Avatar
beat you by 2 mins
Old Jan 3, 2015 | 01:57 PM
Bruce_Benz's Avatar
ML 350
Originally Posted by Nanook
beat you by 2 mins
Touché
Old Jan 4, 2015 | 03:25 AM
MLee's Avatar
ML350 BT soon......pleeeease. GOT IT NOW....Wooooo
Move to Australia mate.......we gottem........
Old Jan 4, 2015 | 04:26 AM
jtorrebl's Avatar
2025 Panamera GTS
My 2012 a6 with leds had them. My dads 2014 and 2012 s class had them. So not being dot compliant doesn't make sense to me. Looking at the housing it looks like it could hold an led cornering light but not sure. Also not sure that it's not there either.
Old Jan 4, 2015 | 10:10 AM
greasykid's Avatar
2015, ML250 BlueTEC
My Cornering Lights
Have had them on 5 previous MB's including the 2013 GLK350 & 2014 C350 Coupe I just traded. Sometimes I cannot follow MB's logic(?). I finally got folding mirrors but lost cornering lights. END OF STORY.
Old Jan 4, 2015 | 11:31 AM
Barry45RPM's Avatar
2015 ML 350
Ah... but your steering wheel's on the wrong side.
Old Jan 6, 2015 | 03:55 AM
swatty's Avatar
220SE Coupe, ML250, E320
No, it's on the right side
Old Jan 6, 2015 | 04:44 AM
MLee's Avatar
And the battery is under the drivers seat.
Old Jan 6, 2015 | 09:18 AM
schorert1's Avatar
2013 ML 550, CLK63 AMG, 2012 E350 4MATIC
That's exactly the issue, they're detailed in the manual but they are not active on your NA ML.
Old Jan 12, 2015 | 06:15 PM
DUTCH's Avatar
Why No Cornering Lights ?
I asked a good friend of mine who is very knowledgeable about automotive lighting. Follows is my question and his response.
Me - "Do you have any idea why MB would have removed the cornering
lights from the 2014 & 2015 M-Class?"
Response - Probably same reason they put red rear turn signals on the US/Canada market: it costs less that way, and better equipment (+cornering lights, +yellow rear turn signals) are merely _permitted_, not required. Contrary to popular belief, even premium carmakers actively pursue cost reduction wherever they feel they can get away with it in a given market. Considering just about every market outside the US now permits truly adaptive headlamps (glare-free high beam/adaptive driving beam), cornering lamps are superfluous. It would not be the first time DB have said "Fine, if the Americans are going to be this stupid and backward about their lighting regulations, they're welcome to stupid and backward lighting".
(I'm sorta curious why the red rear turn signals don't grind your gears...they're demonstrably less safe than proper yellow ones the rest of the world requires).
Old Jan 12, 2015 | 06:43 PM
schorert1's Avatar
Nah, sounds plausible but the GLK has them with the ILS. The ils in the new w166 2012-2013 on has the hardware (the reflector, bulb holder and I would assume the wiring harness) but it's not active...so it's de-featured just to save a pair of bulbs? I've seen a video from a canadian c63 that does have them.
I stand by this system failing some regulator test for light scatter..
I would agree that the ils hid's throws a good amount of light out to the side .
Old Apr 23, 2015 | 10:55 PM
Hoplatani's Avatar
Ml350 bluetech
Pffft
I think he knows his car better than you!!
Old Apr 23, 2015 | 10:58 PM
Hoplatani's Avatar
Ml350 bluetech
Don't loose your precious time
Mr''il ow everything'' is not gonna understand what you mean by your answer, you are right, my brother in law has them in his 2013 in his C serie
Old Apr 24, 2015 | 09:18 AM
Barry45RPM's Avatar
2015 ML 350
The thinking in the US years ago when yellow light bulbs were phased into the US Market was that forward facing bulbs would be Amber and rearward facing bulbs would be red. The same was true for side marker lamps. That way even from some distance away in dark night conditions, you could look at the lights and know if an intersecting car was going slowly from right to left or vice versa, and whether it was approaching or departing from you.
Old Apr 24, 2015 | 04:07 PM
Kartergreg's Avatar
2013 ML350 Bluetec, 2016 C3, 2020 Lincoln Aviator
..... and whether it was approaching or departing from you.
I would have thought the white headlights or red taillights would have been a dead give away.
Old Apr 24, 2015 | 05:07 PM
Barry45RPM's Avatar
2015 ML 350
Back then, up until darkness, as the sun set people first switched on their parking lights.
