'12 bluetech oil cooler leak
Old Nov 16, 2017 | 02:22 PM
dvakata's Avatar
ML350d w166
went to fix it, $1500 later found that oil cooler has an uneven shape, bent on one corner, seems like production defect. Not sure if I have resources to fight with MBUSA...
Just an advise - lease new cars, or buy an extended warranty...
Old Nov 16, 2017 | 03:36 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
I don't understand. You paid $1500 for a bent cooler? Where's it leaking?
Old Nov 16, 2017 | 03:49 PM
dvakata's Avatar
ML350d w166
oil cooler leak is well-known MB issue documented in TSB. To replace gasket there's cost associated, labor plus a long list of gaskets. In my case, after replacing cooler gasket we found that leak can be also initiated by defective oil cooler. Not sure if this fact can be used against MBUSA trying to recover cost of repair
Old Nov 16, 2017 | 04:05 PM
Well, if the dealer replaced gaskets' stuff for $1500 just to realize that a cooler with a TSB is floating around, then hell yeah. I'd scream bloody murder....
Old Nov 16, 2017 | 04:06 PM
dvakata's Avatar
ML350d w166
scream louder, dealer charge is 3K, I went to local indy...
Old Nov 16, 2017 | 04:08 PM
F'ing nuts bud. "German-engineered".
Yeah, whatever...
Old Nov 17, 2017 | 04:23 AM
Waykool plantz's Avatar
Defender 90/360 Modena/2012 MLBTC on order
What is your milage ? My 2012 BTC developed a leak @48500 miles...was fixed under warranty but fear of expensive issues led me to purchase a extended warranty...which is 2500 mikes from expiring.
Old Nov 20, 2017 | 01:56 PM
dvakata's Avatar
ML350d w166
108K km...Getting an extended warranty is a wise thing...
