W166 360 Camera Control Unit
Old Nov 9, 2020 | 01:45 AM
Camillec's Avatar
ML250
Hi All
I'm a newbie member but been using your site for info for quite a while, so thanks for this great site!
I need some help with my ML 250, the 360 camera stopped working and after dealer service checked they advised I need replace the 360 camera control unit and they want big$$ for that,
Has anyone had this issue any ideas how to fix this or alternative way to replace the ECU, and also where is this ECU located in the car so I can see what is the exact model to look for second hand, thanks for your help,
Old Nov 9, 2020 | 09:18 PM
chassis's Avatar
2017 GLE350 4MATIC
Originally Posted by Camillec
Hi All
@Camillec Do you have a list of part numbers from your dealer, that they recommend replacing? Without this, or error codes (do you have a list of them) you are probably best off searching ebay for the unit that matches your search terms. Need more information for a more helpful suggestion.
Old Nov 9, 2020 | 09:40 PM
Camillec's Avatar
ML250
Thanks Chassis, the part # given to replace is 0009001407 Control unit.
Basically the 360 camera just stopped, they tried resetting the program and upgrade software but the ECU apparently is just dead. that is all the details I have from them, thanks for your help,
Old Nov 10, 2020 | 09:03 PM
chassis's Avatar
2017 GLE350 4MATIC
https://mbparts.mbusa.com/oem-parts/...ule-0009001407
Please post your VIN so someone can look up the replacement procedure.
Old Nov 18, 2020 | 08:49 PM
Camillec's Avatar
ML250
VIN WDC166042A249610
Old Nov 26, 2020 | 11:05 PM
Camillec's Avatar
ML250
Hi All
Sorry for the slow response been very busy at work, is anyone able to help me with this thank you,
Old Dec 3, 2020 | 05:09 PM
Camillec's Avatar
ML250
Hi Chassis,
Did something happen cause no one is responding or helping me with this? what do I need to do to have some help? thank you
Old Dec 3, 2020 | 10:04 PM
chassis's Avatar
2017 GLE350 4MATIC
@Camillec Sorry for the delay. I upgraded my computer and WIS isn't working at the moment. If I were you I would start extensively searching this site for the information you are looking for. Alot is available, it isn't often resurfaced via search feature.
Old Dec 4, 2020 | 01:01 AM
we47b1me's Avatar
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
Hi Chassis,
easy tiger....
You don't just ask/demand for help and it magically appears...
We all have day jobs....
You can go to a mechanic with STAR and VEDIAMO and get charged $200 an hour, or be patient.
Old Dec 6, 2020 | 09:05 PM
Camillec's Avatar
ML250
Hi thanks, I didn't expect magic but just there was no response and being new wasn't sure cause reading other threads I see ongoing conversation in comparison, thanks
Old Dec 6, 2020 | 09:07 PM
Camillec's Avatar
ML250
Thanks chassis, how else can I search if not through the search engine,
Old Dec 6, 2020 | 09:29 PM
chassis's Avatar
2017 GLE350 4MATIC
Use the search engine on this site, and google. Google finds things on websites that aren't found using the native forum search engine. Also Google will search the other MB site. Use your best judgement, sorry I am not able to help further until I get WIS back up and running. I don't expect it will be soon.
Old Aug 20, 2021 | 11:39 PM
Camillec's Avatar
ML250
ECU replacement 360 Camera
Hi All
I have solved the initial issue, ECU has been located it is under the passenger seat, took quite a bit of work to get to it but I did, happy to share the experience with anyone who needs help,
I have since replaced the ECU with a second hand part, ECU has been tested and works however it needs SCM coding with the car's VIN# and apparently Merc has control on this, anyone has any other option to do this, cause I am sure if I go to Merc they will charge big $$, thanks
Old Aug 21, 2021 | 09:19 AM
Qikslime's Avatar
ML63
Hi there. Did you remove the seat to get to it? That's what i did, and i cant imagine there is any better way. I ended up with a SRS code or something as apparently you have to disconnect battery before disconnecting power to the seat. Code can be cleared by dealer really easily.
Old Aug 21, 2021 | 09:46 PM
Camillec's Avatar
ML250
Hi Yes I did remove the seat and the SRS can be cleared once you reconnect everything, that is if there is no real fault...
Old Aug 21, 2021 | 11:39 PM
chassis's Avatar
2017 GLE350 4MATIC
You can buy a Xentry/DAS system for SCN coding. Use the search feature on this site.
