Tilt/Telescoping column sticking
Old Jan 23, 2021 | 11:32 AM
gkgeiger's Avatar
'10 C300, '15 ML250BT, '22 M850i Vert
My '15 ML has a problem that when I change driver memory settings the column doesn't move. I have to give the wheel a little nudge. It's like it need a little lube. I do have an extended factory warranty but I'm sure it will work fine at the dealership. Just wondering if this has happened to anyone else?
Old Jan 24, 2021 | 02:32 AM
we47b1me's Avatar
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
You have a warranty. Go to dealer. This is common problem. Don't waste time on an online forum when you can get it fixed for free.
Old Jan 24, 2021 | 07:39 AM
gkgeiger's Avatar
Thanks you for telling me this is a common problem, that's what I was looking for. As far as the rest of your comment, "F O".
Old Jan 24, 2021 | 10:00 AM
MBSang's Avatar
14 ML350 4MATIC
Some some reason, my delear said this issue was not part of my extended warranty (MB warranty), and I need to pay something like $95 or so to fix it. Then, it never come back.
Old Jan 24, 2021 | 10:28 AM
we47b1me's Avatar
ok
Old Jan 24, 2021 | 11:02 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
This is such a common issue. The search feature of the forum would save you time and money. Attempt to move it up or down and bang on the steering column/wheel in the direction you are attempting to move the wheel. Once it frees itself, move it to the direction you want and you may want to exercise it to all available positions.
Old Jan 24, 2021 | 05:35 PM
gkgeiger's Avatar
I did a couple searches and nothing turned up. Know I remember why I quit coming here. Heard enough.
Old Jan 24, 2021 | 08:04 PM
BlownV8's Avatar
MBWorld.org Forums - Search Results
Old Jan 24, 2021 | 10:14 PM
another_geek's Avatar
'16 Jaguar F-Type R, '21 GLE63s
I had this issue on my '13 ML63 for quite some time before I finally mentioned it to my dealer. Dealer performed a software update and it never came back.
Old Jan 25, 2021 | 02:56 PM
gkgeiger's Avatar
Originally Posted by BlownV8
That's good! Just what I found. Thanks,
Old Jan 25, 2021 | 07:03 PM
BlownV8's Avatar
Sorry, link was dead. I will just link a few of the hundred or so matches returned from the search.
Tilt Steering Wheel Problem - MBWorld.org Forums
HOW TO: Fix power steering column that will not move up and down - MBWorld.org Forums
How to Fixed: 2014 ML350 Steering Wheel Tilt Malfunction - MBWorld.org Forums
Steering wheel wont go up or down - MBWorld.org Forums
Steering Wheel Not Tilting - MBWorld.org Forums
tilt steering wheel stopped working... - MBWorld.org Forums
