Merge W166/X166 ML/GLE/GL Forums
The thread that I started is in the Group suggestions sections of the forum.
Below is the Link:
https://mbworld.org/forums/suggestio...one-forum.html
If you could please comment your thoughts here so that the admins will be able to see that there are many group members that support this; it will greatly help.
Thanks!
ML/GLE are on the same chasis the W166. Granted both have the same engines/body style, the facelifted GLE has many different things inside and out. An issue a user would have on the ML is not the same as an issue someone would have on the GLE.
GL/GLS are on the same chasis X166 as well. This car is a three row beast, you cant even discuss an issue with the GL/GLS without confusing someone in the group. there are several variants of the GL as long as the GLS.
It would lead to too much confusion. While I applaud you wanting to do so, long term wont work.
my .02 cents.
my .02 cents.
Plus, to me you haven't made a very good case for merging forums.
Laugh your a** off at my comment if it gives you pleasure.
Another good case I can bring up is that when dealership technicians are looking up WIS for any work they’re doing on these cars. The manual does not signify whether it’s an ML or GLE - it just states W166…. If that doesn’t tell you these forums shouldn’t be merged then idk what to tell you.
Does doing your hair differently make you a different person? Ironically, someone getting "face-lift surgery" does not make them a different person - just refreshes their look, but they are still the same person. Just because there are refreshments from year to year on a car model does not mean that it is a different car. It just happens to be that the ML in 2016 had its nomenclature changed to match the rest of the MB lineups. For example - I replaced my rear air vents on my ML63. The work instructions were the same for a 2014 W166 ML as it was for a 2018 W166 GLE, even used photos from an ML.
If one combines X204 with X253, then all W163/W164/W166 should be combined too because they are 2nd and 3rd generation of the original ML? Of course NOT. Combining GLK with GLC is equivalent to combining W166 GLE with V167 GLE - same name cars, later is the next generation of the former, but are totally different platforms and have nothing in common except the name (someone pointed also to a start on the hood, in a different thread). I have W166 ML and W166 GLE and they are essentially the same car with expected improvements in W166GLE as a facelift of W166ML. I had both GLK and GLC loaners (immediate family member has GLC) and they are totally unrelated and completely different cars.
What other admins could I possibly ask besides speedlimit? I’m wondering because I’ve had no feedback from speedlimit since February when I asked to merge W166 ML/GE and X166 GL/GLS
You are just intolerant of an opinion that differs from yours, and you immediately jump in to "defend" your opinion.
Think about it: If you have to argue with every commenter, maybe your idea isn't the prevailing sentiment?
I'm glad that One Poster didn't cause the moderators to change their format. I wouldn't be surprised if that's what happened with the 166/167 forums.
Idon't think you understand how you do ungrateful work. Why? Because whatever you do or invent, it will never be good for everyone ... Never. It will always be bad. And it doesn't matter if you argue for everyone or nod that they are right, because it will go wrong again ... always. In the Czech Republic we say :: 10 people - 11 opinions ....
Don't think of ML / GLE and GL / GLS because you did it wrong.
If you did it separately, it would also be bad. If it were together, it would be wrong again
If you didn't do anything about it, it would be bad again, because in another forum they put it together.
You have nothing to be sad about - you did a good job and it was definitely not you who tried to convince ... Greetings to the owner of GLE ...
You have nothing to be sad about - you did a good job and it was definitely not you who tried to convince ... Greetingsto the owner of GLE ...
Also, you should update your profile to reflect that you have a W166 GLE. It’s not listed there.
