upgrade HID D1S to LED
Old Jul 16, 2021 | 12:01 PM
ML400's Avatar
2015 ML400
I've had one headlight burned out and need to replace it and was going to do so in pairs. Are their any advantages to going with an LED setup? I have the HID option with the D1S bulbs. I saw the regular light upgrade to LED debacle so I'm hoping my question doesn't start a crap flinging fest. It's just a question.
Old Jul 16, 2021 | 06:26 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
No, just get good bulbs.
Old Jul 19, 2021 | 10:23 AM
Mikey178's Avatar
2013 Mercedes GL350 Bluetec (X166) & 2019 Mercedes A220 (W177) & Retired 2008 Mercedes C300 (W204)
If its halogen - Upgrading to HID will be a vast improvement for visibility (some will argue about glare, light dispersion, etc.....). Can't speak to LED's really.
The stock HID's are good, I'd recommend to get good replacement D1S bulbs and replace them and move on. You do have the option of changing the Kelvin for the bulbs if you want a different look but the 5000k or 6000k are the cleanest look.
Old Jul 21, 2021 | 10:04 AM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Going from HIDs to LEDs without changing the entire headlamp housing to one that properly focuses the light - which does NOT EXIST for the ML - would be a downgrade AT BEST. The light dispersion characteristics of an HID bulb (onmi-directional arc with equal light output in 360 degrees) is very different form that of an LED which has a flat element (directional dispersion in whichever way the diode element(s) is/are pointing). Your existing headlamp housings and lenses are designed for the first, not the second.
Glad to see another 928 owner on the forum!
Old Jul 21, 2021 | 05:17 PM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
I would say go with @AZN Optics They have good options.
Old Jul 21, 2021 | 09:03 PM
BullDozer's Avatar
W166 ML350 BlueTec
What would you say is the best looking (whilst also having an effective output) upgrade for the HID ILS headlights? I've seen the Osram XenArc Cool Blue Intense D1S mentioned quite a lot.
Old Jul 22, 2021 | 11:58 AM
GLK Super Fan's Avatar
GLK250 ML350
That the one I am currently using. It works really good.
Old Oct 12, 2021 | 06:48 PM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
Left side low beam on wife's '14 ML350 just went out. Any complications changing to the Osram? Plug and play? Thanks.
Old Oct 12, 2021 | 07:04 PM
GLK250 ML350
https://mbworld.org/forums/m-class-w...-thread-4.html
Check out my build thread post number 93 to 95, i documented the d1s bulbs i tried and the installation video
Old Oct 13, 2021 | 10:31 AM
pjw1967's Avatar
Thank you very much for that link. Just did a dry run. The bulb came out easily but going back in wasn't. I had to use long needle nose pliers to get enough leverage to turn it clockwise the last few degrees. New bulbs on the way.
Old Oct 13, 2021 | 11:00 AM
GLK250 ML350
Osgram CBB 7k worked the best. I also got 2 years extended warranty from amazon. Sometimes you have to aligned good to put back the bulbs. That being said, i still have a hard time to put the bulbs back in from time to time.
Old Oct 15, 2021 | 04:23 PM
pjw1967's Avatar
Again, thanks. Got the 2 replacements in. Never would have done it without the curved needlenose.
