Mercedes-Benz BlueTEC II Settlement in Canada
no refund will be done for part who was replaced before. example : customer came in october 2021 for his ML350 2012. His exhaust DPF was replace at his cost. (pay around 4000$ parts and labor) .
SAB bluetec settlement open in 2022. We will replace his DPF for a new one again, but customer can't be refund for his old replacement cost .
First step in dealer process for Bluetec Settlement. If you have a DPF/SCR delete , they stop the process and give u back the key , because the car isnt in the originale form. DPF/SCR and both NOX sensor and SOOT sensor need to be there for the repairs.
IF u only have a tune. Repairs will be done, but after all the components are install, dealer will do a 30min ecu's coding/update. so you will lost you Tune data.
This is my 2 cents, but when the Bluetec settlement ServiceAction is done. you get a extra warranty of 4years/77 0000km extra on many things :
-all adblue components (all heating elements,pump , injectors) EXCEPT THE ADBLUE PRESSURE LINE (i know its stupid)
-all exhaust components ( nox, soot, temperature system)
-EGR systems (valve, duct, cooler, temperature sensor)
-Intake manifold (swirl flap and motor)
- TIMING CHAIN. (if it noisy at start up, go replaced it under warranty)
-turbocharged
-PCV
-MAF sensor
-Engine heads (valve train, ect)
-Injectors
If you are a former owner, it certainly may take that long simply because the current owners have until May 1, 2023 to complete the AEM and file. As for the current owners, parts are still scarce and not even yet available for some model years. I know people in the US that have been waiting for about a year now since they filed, and we started considerably later on this side of the border. The law firms and settlement administrators are not exactly expedient... I'd be quite surprised if any of us see anything before the end of the year.
Thought something was starting to go wrong with my GL, but now that I think about it, it started right when I got it back from the Field Measure installation.
Sounds like they tried to improve emissions by making the fuel pump inject fuel once the engine is already cranking for a second, rather than starting it at the same time it cranks.
No changes in my GL with respect to fuel economy, performance, or anything else. Dealer parts guy I know told me yesterday that a few people still haven't had it done because they are doing their "research" before they book an appointment. He implied that some people think it will decrease fuel economy or make the truck worse.
His exact comment at the end was "why wouldn't you have it done? You get all new parts AND a warranty too. And the warranty covers other stuff that fails like timing chains and DEF pumps". Remember this is the parts manager and he knows what parts he sells a LOT of for specific models.... So him saying timing chains or DEF pumps being under warranty is based on # of those parts he sells every day.
If you haven't had it done, go get it done now! The settlement cheque is almost just icing on the cake on top of the free parts and free warranty!
The one thing that I'd did find quite odd is that there is now a second OBD connector hanging down by the original one (see pic below). Does anyone else have one of these? And secondly, what's the purpose of the 2nd one?
P.S. Just re-read your post... not on a '15 so it may have been from a previous job (or possibly if they ran into some issues), but either way , it is not supposed to be there. Someone was in a hurry.
I'm simply curious if anyone else has experienced this (before I take my vehicle back into the dealership)? Thanks!
Where is it leaking from?
