Mercedes-Benz BlueTEC II Settlement in Canada
Good day!
Im having my field measure appointment this August 15, 2022 for my 2011 GL 350.Once completed will it have
an extended modification warranty With regards to engine timing Chain. I have noticed that my vehicle is having issues already on its engine timing chain due to rattling sound at cold start only.. Do you have any idea if this is included after the field measure install.. would they also include /fix the issue under extended modification waranty. Because it is stated in the document regarding extended modification some systems are under the warranty. Any insights about this? Hoping for your reply.
btw 125000km milage ThanksLast edited by Jubbs; Aug 3, 2022 at 04:00 PM.
Has anyone else had any problems after the field measure was installed?
Note that they probably didn't cover it because it's not part of the DPF. Even though it is called "DPF sensor" it is actually before the DPF in the exhaust pipe if I recall correctly. It senses back pressure to know if the DPF is clogged etc. So although it is called DPF sensor it is not part of the DPF itself that they replaced.
I do recall it not being hard on my X164 (GL320) and it's likely the same on the GL350. I was able to crawl under the truck, remove it, and unplug/replug the connector. Took 5 mins and can be ordered online. I don't recall if I used any wrenches or anything.. it may have actually been a twist off/twist on situation, or maybe there was a simple clip. Looking at the new one should tell you.
These used to go bad all the time. I had 3 go bad within a span of about 100,000km (60k miles) then for the next 100,000km never had a problem at all. I suspect they keep updating the part and finally got it right. Last one I ordered was in 2016, so it is likely the 2013-2016 GL350 still had one of the older part #'s on it (if it is original and hasn't been replaced yet). Make SURE to get the latest part number when you order.. lots of old stock floating around!
Overall power & torque seem similar to before (this is a very subjective assessment)
Fuel economy seems similar (after about 1 tank of fuel)
Off-the-line seems to exhibit a very exaggerated turbo-lag response... below 1800 RPM is just super sluggish. I think this is software-programmed, as it doesn't seem to matter how hard I apply the accelerator, it is just the same sluggishness to about 1800-2000RPM. If you mash it hard from a standstill, you get slow-slow-slow-whiplash as it leaps to life at 2000RPM.
Anyone else seen this behaviour?
They also noticed that my suv was barely leaking oil (I already knew that). They said the oil cooler seals were the culprit (surprise surprise...) and they wanted 2600$ to do the job. I declined since it's barely leaking and my local indy shop can do it for less. They also said my transmission oil pan gasket was slighly leaking. They wanted 600$ for that. I declined (I can do that myself).
*** Update *** Called the dealership and they said the gearing box recall wouldn't have done that. Strange... I'm 99% sure that it wasn't there before I brought the suv in. Maybe the tech hit a pothole while doing a test drive? Anyways, I'll call my local german indy garage to schedule an alignment (I was probably due for one anyways).
For the steering gear bolts replacement. We need to remove steering rack from mounting points. AND after the job, in the recall procedure its said : Perform wheel alignment and carry out the toe adjustment.
Maybe your dealer didnt do it . Yes the recall can affect your wheel alignement, adjustement need to be done at the end.
For your oil leak. Oil cooler(oil-water heat exchanger) is a common problems. It's a 9 to 12 Hours job and needs to remove the intake manifold. The question is: WHY the dealer didn't tell you it was leaking during they did intake manifold replacement? The oil cooler is under the intake manifold. its like 2 hours to clean and replace cooler seals when intakes manifold are remove
All other things being equal, when you're driving on a a two-lane city street or highway, a perfectly aligned steering wheel should technically be pointing slightly to the left as you are essentially steering to the left in order to overcome the pull due to the crown of the road (which pulls the vehicle to the right, i.e. away from oncoming traffic). If you get on a six-lane divided highway and drive in the center lane (or you have a stretch of road to yourself and can perfectly straddle the same driving in the middle right over the yellow line), does the steering wheel still point to the left or is it perfectly centered?
I had a similar issue with my ML a while back and kept bringing it back. After the third attempt they discovered that their alignment rack was miscalibrated, at which time they called in their Hunter tech to recalibrate the alignment rack and the car came out the way it should be.
I called (Star Motors in Ottawa) to schedule an appointment for them to look at it and fix the steering wheel alignment issue. The lady on the phone said they're fully booked until mid November... Wtf! I booked my appointment, but will look at the other dealership in Ottawa for something sooner...
. It was for $2700 and change.
I had an CEL on the way home from the field measure appointment in February for the EGR valve, which I was finally able to get replaced under the new extended warranty, so I am hoping it is good for a while now. EGR valves are a long wait time right now.
Sounds like the first batch of cheques has gone out all at once this week. Maybe all of them but from the posts here it seems everyone who submitted March/Apr is starting to receive a cheque.
I am in Canada of course (as per thread title)
For more about the Settlement, please review the Settlement Agreement found on the Important Documents page of the website www.BlueTECSettlement.ca."
We purchased our 2012 ML350 Bluetec in the U.S. and brought it over to Canada in August 2012. I was planning on getting the Field Measure update on the vehicle last September but the Service Department at the MB dealership, where I have just purchased a new 2022 GLE450, in Ont, neglected to contact the MB National Warranty office to confirm VIN, so we cancelled the appointment. The appointment was re-scheduled for next Monday, so I called the service dept to confirm they had called to confirm VIN. The person that I spoke to is now saying that the Field Measure update is part of a "campaign" and that the dealership may not be legally required to do the update... Has anyone else had any pushback from any dealership? Thx!
Anyone have the same issue? I've emailed settlement group twice, haven't heard back. Thanks
