Mercedes-Benz BlueTEC II Settlement in Canada
if they refuse ask to be shown the bulletin where it says that
There is a copy floating around as a PDF. I have seen it but don’t have a copy. Maybe someone here has it or you can find it. Then you can verify 100% that it doesn’t say anything about engine being original.
if I remember correctly the only issue is aftermarket modifications. If you have an aftermarket air intake, exhaust, removed DPF, etc. Only then was it an issue if I recall.
Anyway, car is in the shop, I will post update when I will hear fron them.
I don't know if someone has an ideea ,what will happen after 01of May 2023 regarding the filling claims on Karla's website (I mean they will not take anymore claims after 01May2023?)
I took an appointment in november 2022 to do that field measure to my GL320 2009 (bluetec) but they postponed me three times and last appointment they offered me is on the 24 of April ..
There is less time remaining to do the job on my car as they need to check also the airbag and the brake-booster...
Here in Laval quebec it takes months to get an appointment at MB dealer as they are arguing each time is the tire season ....their best speciality I think...
I received a letter in February 2023 (a year after my claim was submitted) which said my claim was deficient because it did not include sufficient proof that I owned the eligible vehicle which was not true, I had submitted a copy of the transfer and a copy of the registration. I resubmitted the same documents and directed the reviewer to the sections which showed I was the owner at the required dates. In March 2023 I received confirmation that the documents had cured tmy claim (it didn't need curing) and that I should follow up in two weeks to determine a payment date. I followed up two weeks later and was told my claim was approved and to expect payment in April 2023.
So...as with many things in life, low expectations are key. Expect slow processing and incompetence and you will not be let down. They were not trying to screw me, they just don't have enough resources and are bad at their jobs. I will confirm when I receive payment which I expect will arrive by this time next year (see, low expectations!).
Anyone else run into this?
What exactly is the point of your post? I mean, what is it that you expect to get out of posting here? Aside from announcing to everyone that you lack basic comprehension and economic skills, what is it exactly that you and all other one-post wonders like yourself are hoping to gain by whining here? Sympathy for the bad decisions you've made?
Given the approaching deadline, I’m considering sending it via courier with a signature required for receipt just to prove that I did submit in time.
The quality of repair from the dealership is horrendous
I physically will inspect car each time car is returned snd always either
there is a loose part
or missing component
or damaged tread or bolt
broken parts
Paid extra to have oil cooler seal replaced. Car was leaking oil when returned and still leaks oil. I can see the engine valley hole is wet
Did they actually do the work? I don’t know…
Or they missed something doing the job that’s causing the leak
And now the rattling that I thought was from loose heat shield is actually from the new Catalytic converter/ dpf
Finally received an email confirmation that the claim had been received, approved, and to expect payment in May so it appears all is in order.
Car sold to the first person to look at it, so all is well except for the crappy experience with the Vaughan dealer.
The extended warranty covers only specific components tied to the recall itself (and I don't even know if it's transferable), so a blanket statement that "any buyer of the car would get an extended warranty from mercedes" is not technically correct. Furthermore, that limited warranty on those specific components only kicks in after the vehicle has had the recall work performed, so your question whether "new buyers of mls become eligible for the recall" is moot because if there is a warranty, it implies that the recall has already been done. If the recall hasn't been done yet, I would walk away from it because the only reason why it would not have been completed by now is because the car is either molested (with an EGR / DEF delete kit, tune or emulator) and/or not in proper working order, which is necessary for Mercedes to pay for a dealership to perform the recall. While anyone can have the recall done, if it hasn't had it done by now chances are that there's another reason for it. Last but not least, chances are that once someone has the recall done, they will be holding on to their car for at least as long as that limited warranty lasts, because the car was properly working and because the things that usually fail are now warrantied - so why would anyone decide to sell a car that is fully paid for and not going to cost them any significant amount of money in R&M for another three or four years?
Don't get me wrong - I love the diesels, but I bought mine new with the intention of keeping them long-term and have maintained then to considerably higher standards than the bare minimums prescribed by Mercedes, our pumps don't put out more than B5, and I don't use them as grocery getters. A used diesel ML - especially at the age they're at now - would in general be a bad bet if you don't know the complete history and condition of the car. If you can wrench on it yourself it may make the purchase more attractive, but from your post it is fairly obvious that you would need someone else to work on it and it may easily end up costing you three times as much as the purchase price of the vehicle itself just to get it sufficiently fixed up for it to be reliable for a few more years.
You can get the VIN checked at MD dealership for any warranty details, if that is all you want to confirm
