ML-166 250 cdi canbus missing signal
Old Apr 17, 2022 | 04:58 PM
Geiroh's Avatar
w212
Hello
Does anyone have a tip to diagnose these?
ML 250 cdi. w166. vin WDC1660041A005379 -
The car stops at the intersection or sometimes when its put into gear. It’s also coughing and almost stops before it runs again.
-The EZS, ECU, Throttle body, Battery, Dynamo, is changed, and still no change. There is no wiring problem?! have overlooked it. All others canbus have a signal.
The Benz dealer gave up so now it’s my turn to try to find what’s wrong.
The car does not have keyless go....
EZS - Electronic Ignition lock(N73) 1 problem exists
1.U10382A Communication with the diagnostic CAN bus has a
malfunction. There is no signal change.
IC - Instrument cluster(A1) 1 problem exist
1.U114587 Communication with KEYLESS GO has a
malfunction. The message is missing.
ECM - Engine Control Module (CDI) 1 problem exist
1.P061B85 The torque calculation of the control unit has a
malfunction. There is a signal above the permissible limit value.
STORED
DTR - DISTRONIC(A89) 1 problem exist
1.630200 CAN communication with control unit ''N62/1 (Radar
sensors control unit)'' or ''N30/4 (Electronic Stability Program
control unit)'' has a malfunction.
Old Apr 17, 2022 | 09:10 PM
chassis's Avatar
2017 GLE350 4MATIC
What is the history of this vehicle? How long have you owned it? Who did you buy it from (private person, dealer, company)? What year is it? How many miles/kms? What modifications are done? Was it in an accident?
Old Apr 18, 2022 | 03:17 AM
Geiroh's Avatar
w212
The car is 2011, owned car since 2017 and the problem started in 18.
It was bought from a dealer. Now it has driven 200' km. No mod was done before this happened.
The car was tuned in 2020 but no change in the behavior. Same ****.
I have not checked the inlet manifold or EGR valve for soot - will do that later.
Can missing of vacuum make this engine stop problem?
Old Apr 18, 2022 | 09:27 PM
chassis's Avatar
2017 GLE350 4MATIC
Do you have a dashcam installed on this car?
Old Apr 19, 2022 | 06:41 AM
Geiroh's Avatar
w212
No
Old Apr 19, 2022 | 10:20 AM
mike919's Avatar
86 190E 2.3, 2014 ML350 Bluetec
Crank sensor checked?
Old Apr 19, 2022 | 10:32 AM
Geiroh's Avatar
w212
Yes. Cant find anything wrong with the sensors - seems ok all of them.
Old Apr 21, 2022 | 07:39 PM
chassis's Avatar
2017 GLE350 4MATIC
What do you think it is? What does your gut tell you?
